Building a Predictive Maintenance Plugin with the InfluxDB 3 Processing Engine
Charles Mahler
Jun 09, 2026
Predictive maintenance is one of the most compelling use cases for time series data. Instead of waiting for equipment to fail or servicing it on a fixed calendar regardless of condition, you watch the live sensor data and act when it indicates that a failure is coming. That “watch the data and act” loop is exactly what the InfluxDB 3 Processing Engine was built for.
In this tutorial, we’ll build a working predictive maintenance plugin from scratch. We’ll install InfluxDB 3 Core, load a well-known public dataset of jet engine sensor data, write a Python plugin that runs inside the database to estimate each engine’s Remaining Useful Life (RUL), and have it raise maintenance alerts automatically. By the end, you’ll have an end-to-end system that you can adapt to pumps, motors, HVAC units, CNC machines, or any other instrumented asset.
What we’re building
Here’s the architecture at a glance:
- Sensor data lands in InfluxDB 3 Core. We’ll use NASA’s C-MAPSS turbofan engine degradation dataset, replayed into a
sensorstable as if it were arriving live from a fleet of engines. - A scheduled plugin runs every minute. It queries the most recent sensor readings per engine, computes a health/degradation score, and converts that into an estimated Remaining Useful Life.
- The plugin writes its conclusions back into the database. RUL estimates go into a
rul_estimatestable, and when an engine crosses a danger threshold, the plugin writes a row into amaintenance_alertstable and logs a warning.
The key idea is that the analysis logic lives embedded in the database. There’s no separate service to deploy, scale, or keep in sync. When data arrives, the engine acts on it.
Prerequisites
Before starting, make sure you have:
- A Linux or macOS machine (Windows works too via the installer or Docker; commands below assume a Unix-like shell)
- Command-line access
- Python 3 installed locally
- The
train_FD001.txtfile from the C-MAPSS dataset
That’s it. InfluxDB 3 Core itself is a single binary and brings its own bundled Python for plugins.
Install InfluxDB 3 Core
The quickest path is the official install script, which always pulls the latest release:
curl -O https://www.influxdata.com/d/install_influxdb3.sh \
&& sh install_influxdb3.sh core
When the script finishes, confirm it worked:
influxdb3 --version
If the influxdb3 command isn’t found, the installer’s output tells you what to do—usually it’s a matter of sourcing your shell config (for example source ~/.bashrc or source ~/.zshrc) so the new binary is on your PATH.
Docker
If you’d rather containerize, the Processing Engine is enabled by default in the Docker image (the plugin directory defaults to /plugins):
docker run -it -p 8181:8181 --name influxdb3-core \
--volume ~/.influxdb3_data:/var/lib/influxdb3 \
--volume ~/.influxdb3_plugins:/plugins \
influxdb:3-core influxdb3 serve \
--node-id my_host \
--object-store file \
--data-dir /var/lib/influxdb3 \
--plugin-dir /plugins
For the rest of this tutorial we’ll assume the local binary install. The commands translate directly to Docker by prefixing docker exec -it influxdb3-core.
Start InfluxDB with the Processing Engine enabled
The Processing Engine activates only when you tell InfluxDB where your plugins live, using the --plugin-dir flag.
First create a directory to hold plugins, then start the server:
mkdir -p ~/influxdb3/plugins
influxdb3 serve \
--node-id host01 \
--data-dir ~/.influxdb3 \
--plugin-dir ~/influxdb3/plugins
A few notes on these flags:
--node-idis a unique name for this server instance. It forms part of the storage path.--object-store filekeeps everything on a local disk under--data-dir. In production you’d point this at S3 or another object store; InfluxDB 3 uses a “diskless” architecture where object storage is the source of truth.--plugin-diris the directory the engine scans for plugin files. This is the switch that turns the Processing Engine on.
Leave this server running in its own terminal. Open a second terminal for the remaining commands.
It’s worth noting that the influxdb3 binary depends on an adjacent python/ directory that ships alongside it. If you extracted from a tarball manually, keep the binary and that python/ folder in the same parent directory and add the parent to your PATH, don’t move the binary out on its own, or plugins won’t run.
Create an admin token
InfluxDB 3 Core uses token authentication. Several operations require an admin token. Create one with the following command:
influxdb3 create token --admin
This prints a token string once. Copy it somewhere safe; you can’t recover it later (you’d have to regenerate). For convenience in this session, export it:
export INFLUXDB3_AUTH_TOKEN="paste-your-token-here"
The CLI automatically picks up INFLUXDB3_AUTH_TOKEN, so you won’t have to pass --token on every command.
Create a database
Create a database to hold our data:
influxdb3 create database engine_fleet
Verify it exists:
influxdb3 show databases
You should see engine_fleet in the list.
Load the dataset into InfluxDB
The C-MAPSS file is a flat, headerless, space-separated table. We need to turn each row into a time series point. There’s one wrinkle worth thinking through: the data has a time_cycles counter per engine, not real timestamps. To make this behave like a live stream, we’ll synthesize timestamps by mapping each engine cycle to one second of wall-clock time, anchored to “now minus the engine’s lifetime.” That way recent cycles look recent, which is what a scheduled “look at the last N minutes” plugin expects.
Here’s a small loader script. It uses the InfluxDB 3 Python client to write line protocol in batches. First install the client into your local Python (this is separate from the engine’s bundled Python), using uv or venv for package management if desired::
pip install influxdb3-python pandas
Save the following as load_cmapss.py, adjusting DATA_FILE and TOKEN as needed:
# load_cmapss.py
import time
from datetime import datetime, timedelta, timezone
import pandas as pd
from influxdb_client_3 import InfluxDBClient3, Point
# ---- Configuration ----
DATA_FILE = "train_FD001.txt"
HOST = "http://localhost:8181"
DATABASE = "engine_fleet"
TOKEN = "paste-your-admin-token" # or read from env
# ---- Column names (NASA C-MAPSS layout) ----
index_cols = ["unit_number", "time_cycles"]
setting_cols = ["setting_1", "setting_2", "setting_3"]
sensor_cols = [f"s_{i}" for i in range(1, 22)]
col_names = index_cols + setting_cols + sensor_cols
# ---- Read the space-separated file ----
df = pd.read_csv(DATA_FILE, sep=r"\s+", header=None, names=col_names)
df = df.astype({"unit_number": int, "time_cycles": int})
print(f"Loaded {len(df)} rows across {df['unit_number'].nunique()} engines")
# ---- Synthesize timestamps: 1 cycle == 1 second, anchored so the
# last cycle of each engine lands at 'now'. ----
now = datetime.now(timezone.utc)
client = InfluxDBClient3(host=HOST, database=DATABASE, token=TOKEN)
points = []
BATCH = 5000
# Per-engine max cycle so we can anchor each engine's final cycle to "now"
max_cycle = df.groupby("unit_number")["time_cycles"].transform("max")
df["ts"] = [
now - timedelta(seconds=int(mc - tc))
for mc, tc in zip(max_cycle, df["time_cycles"])
for row in df.itertuples(index=False):
p = (
Point("sensors")
.tag("unit_number", str(row.unit_number))
.field("time_cycles", int(row.time_cycles))
for c in setting_cols + sensor_cols:
p = p.field(c, float(getattr(row, c)))
p = p.time(row.ts)
points.append(p)
if len(points) >= BATCH:
client.write(points)
points = []
if points:
client.close()
print("Done writing sensor data.")
Run it:
python load_cmapss.py
A few design choices worth calling out:
unit_numberis a tag, everything else is a field. Tags are indexed and are how you separate one engine’s series from another. Sensor values and the cycle counter are fields.- We anchor each engine’s final cycle to “now.” This means every engine in the fleet looks like it just reached end-of-life, which is convenient for demonstrating alerts. In a real deployment your data already has real timestamps and you’d skip all of this.
- Batching matters. Writing 20,000+ points one at a time is slow; batches of a few thousand keep the loader quick.
Confirm the data landed:
influxdb3 query --database engine_fleet \
"SELECT COUNT(*) FROM sensors"
And take a peek at one engine's recent readings:
"SELECT time, unit_number, time_cycles, s_2, s_4, s_11 \
FROM sensors WHERE unit_number = '1' \
ORDER BY time DESC LIMIT 5"
An overview of the plugin model
Before writing code, let’s get the mental model straight.
A plugin is a Python file (or a directory with an __init__.py for multi-file plugins) placed in your plugin directory. It defines a function whose signature matches the trigger type:
- Data-write plugin:
def process_writes(influxdb3_local, table_batches, args=None):</pre> - Scheduled plugin:
def process_scheduled_call(influxdb3_local, call_time, args=None):</pre> - HTTP-request plugin:
def process_request(influxdb3_local, query_parameters, request_headers, request_body, args=None):</pre>
A trigger is the database resource that connects an event to a plugin. You create it with influxdb3 create trigger, specifying a trigger spec that defines when the plugin runs.
Whatever the type, every plugin receives influxdb3_local which is the shared API object that’s your gateway to the database. The methods we’ll use:
influxdb3_local.query(sql)- run a SQL query and get results back as a list of dictionaries.influxdb3_local.write(line)- write a point back into the database, built with theLineBuilderhelper.influxdb3_local.info(msg)/.warn(msg)/.error(msg)- log to stdout and the system.processing_engine_logs table.- The engine also offers an in-memory cache for keeping state between runs (useful for things like tracking a rolling baseline), though we’ll keep our first version stateless.
LineBuilder is the recommended way to construct a point inside a plugin:
line = LineBuilder("my_table")
line.tag("device", "pump_7")
line.float64_field("value", 42.0)
line.int64_field("count", 3)
Plugins receive trigger arguments as a Dict[str, str] in args, which is how we’ll pass tunable thresholds without editing code.
Predictive maintenance plugin logic
We need to turn raw sensor readings into a Remaining Useful Life estimate. A full production system might run a trained LSTM or gradient-boosted model, but a tutorial plugin should be transparent and dependency-light, so we’ll use a degradation-index approach that captures the real idea behind RUL prediction without a black box:
- Pick the sensors that carry degradation signals. In FD001, several sensors drift steadily as the high-pressure compressor wears. Sensors s_2, s_3, s_4, s_8, s_11, s_13, and s_15 trend upward over an engine’s life; s_7, s_12, s_20, and s_21 trend downward. (Some sensors in FD001 are flat and carry no information—we ignore those.)
- Normalize each chosen sensor against the healthy-baseline range so they’re comparable, flipping the downward-trending ones so “more degraded” always means “higher.”
- Average them into a single health index between roughly 0 (factory-fresh) and 1 (failure imminent).
- Map the index to an RUL estimate. Using the dataset convention that degradation becomes meaningfully predictable in roughly the final 125 cycles, we estimate
RUL ≈ 125 × (1 − health_index). - Alert when the estimated RUL drops below a configurable threshold.
This is intentionally simple and explainable. The plugin structure is identical whether the scoring function is ten lines of arithmetic or a 50-megabyte neural network, you’d just swap the body of compute_health_index.
To normalize, the plugin needs each sensor’s healthy and degraded reference values. Rather than hard-code magic numbers, we’ll derive them once at the top of each run from the fleet itself with the early-life readings approximate “healthy” and the latest readings approximate “degraded.”
Creating the plugin
Create the plugin file directly in your plugin directory. Save this as ~/influxdb3/plugins/predictive_maintenance.py.
# predictive_maintenance.py
# Scheduled plugin: estimates Remaining Useful Life (RUL) for each engine
# from the most recent sensor readings, writes the estimates back into the
# database, and raises alerts when RUL drops below a threshold.
# Sensors that rise as the engine degrades
RISING = ["s_2", "s_3", "s_4", "s_8", "s_11", "s_13", "s_15"]
# Sensors that fall as the engine degrades
FALLING = ["s_7", "s_12", "s_20", "s_21"]
# Convention from the C-MAPSS literature: degradation becomes meaningfully
# predictable in roughly the final 125 cycles.
MAX_PREDICTABLE_RUL = 125.0
def _safe_float(value, default=0.0):
try:
return float(value)
except (TypeError, ValueError):
return default
def compute_baselines(influxdb3_local):
"""Derive healthy and degraded reference values for each sensor.
Healthy ~ average of the earliest cycles across the fleet.
Degraded ~ average of the latest cycles across the fleet.
sensors = RISING + FALLING
avg_cols = ", ".join([f"AVG({s}) AS {s}" for s in sensors])
healthy_rows = influxdb3_local.query(
f"SELECT {avg_cols} FROM sensors WHERE time_cycles = 15"
degraded_rows = influxdb3_local.query(
f"SELECT {avg_cols} FROM sensors WHERE time_cycles = 175"
if not healthy_rows or not degraded_rows:
return None
healthy = healthy_rows[0]
degraded = degraded_rows[0]
baselines = {}
for s in sensors:
lo = _safe_float(healthy.get(s))
hi = _safe_float(degraded.get(s))
baselines[s] = (lo, hi)
return baselines
def normalize(value, lo, hi):
"""Scale a reading to 0..1 between the healthy (lo) and degraded (hi)
references. Clamps to the [0, 1] range."""
if hi == lo:
return 0.0
frac = (value - lo) / (hi - lo)
return max(0.0, min(1.0, frac))
def compute_health_index(reading, baselines):
"""Combine the signal-bearing sensors into a single 0..1 degradation
index. 0 = healthy, 1 = failure imminent."""
scores = []
for s in RISING:
lo, hi = baselines[s]
scores.append(normalize(_safe_float(reading.get(s)), lo, hi))
for s in FALLING:
# Falling sensors: degraded value is lower, so invert the scale.
scores.append(1.0 - normalize(_safe_float(reading.get(s)), hi, lo))
if not scores:
return 0.0
return sum(scores) / len(scores)
# --- Read tunables from trigger arguments ---
args = args or {}
rul_threshold = float(args.get("rul_threshold", "30"))
lookback = args.get("lookback", "10m")
f"Predictive maintenance run starting. "
f"rul_threshold={rul_threshold}, lookback={lookback}"
# --- Build per-sensor baselines from the fleet ---
baselines = compute_baselines(influxdb3_local)
if baselines is None:
influxdb3_local.warn("Not enough data to compute baselines; skipping run.")
return
# --- Get the most recent reading per engine ---
sensor_select = ", ".join(RISING + FALLING)
latest = influxdb3_local.query(
f"""
SELECT unit_number, time_cycles, {sensor_select}
FROM sensors
WHERE time >= now() - INTERVAL '{lookback}'
ORDER BY time DESC
if not latest:
influxdb3_local.warn("No recent sensor data in lookback window.")
return
# Keep only the newest row per engine (results are time-desc ordered).
seen = set()
newest_per_engine = []
for row in latest:
unit = row.get("unit_number")
if unit not in seen:
seen.add(unit)
newest_per_engine.append(row)
alerts = 0
for row in newest_per_engine:
unit = str(row.get("unit_number"))
cycles = int(_safe_float(row.get("time_cycles")))
health = compute_health_index(row, baselines)
est_rul = round(MAX_PREDICTABLE_RUL * (1.0 - health), 1)
# --- Write the RUL estimate ---
est = LineBuilder("rul_estimates")
est.tag("unit_number", unit)
est.float64_field("health_index", round(health, 4))
est.float64_field("estimated_rul", est_rul)
est.int64_field("time_cycles", cycles)
influxdb3_local.write(est)
# --- Raise an alert if the engine is in the danger zone ---
if est_rul = rul_threshold:
alerts += 1
severity = "critical" if est_rul = rul_threshold / 2 else "warning"
alert = LineBuilder("maintenance_alerts")
alert.tag("unit_number", unit)
alert.tag("severity", severity)
alert.float64_field("estimated_rul", est_rul)
alert.float64_field("health_index", round(health, 4))
influxdb3_local.write(alert)
f"[{severity.upper()}] Engine {unit}: estimated RUL "
f"{est_rul} cycles (health index {round(health, 2)}). "
f"Schedule maintenance."
f"Run complete. Scored {len(newest_per_engine)} engines, "
f"raised {alerts} alert(s)."
Let’s walk through the important parts.
- Baselines from the data help us avoid any magic numbers. -
compute_baselinesasks the database for the average sensor values during early life (cycles ≤ 15, “healthy”) and late life (cycles ≥ 175, “degraded”). This adapts automatically to your fleet and means you don’t have to know the absolute scale of s_4 in advance. - A single, explainable health index.
compute_health_indexnormalizes each signal-bearing sensor onto a 0–1 scale and averages them. Rising and falling sensors are both oriented so that 1 always means “more degraded.” This is the piece you’d replace with a trained model in production — the surrounding plumbing stays identical. - Newest reading per engine. The query pulls everything in the lookback window ordered newest-first, then we keep the first row we see for each
unit_number. Because of how we loaded the data (each engine’s last cycle anchored to “now”), the most recent rows are the most degraded. - Writing conclusions back. Every engine gets a row in
rul_estimates. Engines past the threshold also get a row inmaintenance_alerts, tagged with aseverityderived from how deep into the danger zone they are, plus a logged warning you’ll see in the server terminal. - Configurable via trigger arguments.
rul_thresholdandlookbackcome fromargs, so you can retune behavior by recreating the trigger.
Creating the trigger
Now connect the plugin to a schedule. We’ll run it every minute, with a 30-cycle RUL alert threshold and a 10-minute lookback window:
influxdb3 create trigger \
--trigger-spec "every:1m" \
--path "predictive_maintenance.py" \
--trigger-arguments "rul_threshold=30,lookback=10m" \
pdm_scheduler
Breaking that down:
--trigger-spec "every:1m"runs the plugin once a minute. You could also usecron:for calendar schedules, for examplecron:0 0 8 * * *for 8am daily (the format includes seconds).--path "predictive_maintenance.py"is the filename relative to your plugin directory. (For a multi-file plugin you’d point this at the directory containing__init__.pyinstead.)--trigger-argumentspasses our tunables as key=value pairs.pdm_scheduleris the trigger’s name.
The trigger is enabled by default and starts running on the next interval boundary.
Testing out the plugin
Within a minute, the plugin fires. Check the server terminal and you’ll see the info and warn log lines. Now query what it produced.
The latest RUL estimates, most-degraded first:
"SELECT unit_number, estimated_rul, health_index, time_cycles \
FROM rul_estimates \
ORDER BY time DESC, estimated_rul ASC LIMIT 15"
The maintenance alerts:
"SELECT time, unit_number, severity, estimated_rul, health_index \
FROM maintenance_alerts \
ORDER BY time DESC LIMIT 20"
If you want to confirm the plugin is registered and see its file details:
influxdb3 show plugins
And the engines flagged critical right now:
"SELECT unit_number, estimated_rul FROM maintenance_alerts \
WHERE severity = 'critical' ORDER BY estimated_rul ASC"
You should see a spread of RUL estimates across the fleet, with the most-degraded engines surfacing as warnings or criticals.
Inspecting logs and iterating
Plugin logs go both to the server’s stdout and to a system table, which is handy for debugging without scrolling the terminal:
"SELECT * FROM system.processing_engine_logs ORDER BY time DESC LIMIT 20"
When you change the plugin code, you don’t need to recreate the trigger. Edit the file and push the update, preserving the trigger’s configuration and history:
influxdb3 update trigger \
--trigger-name pdm_scheduler \
For local development you can also develop a plugin on your own machine and upload it with --upload when creating or updating a trigger, which copies the file to the server for you (this requires an admin token). And if you want to dry-run a scheduled plugin without waiting for the interval, there’s influxdb3 test schedule_plugin.
To pause the system without deleting anything:
influxdb3 disable trigger --database engine_fleet pdm_scheduler
# ...and later...
influxdb3 enable trigger --database engine_fleet pdm_scheduler
Error Handling
By default, plugin errors are logged and the trigger keeps going. For a critical pipeline you might prefer automatic retries or auto-disable. Set this when creating the trigger with --error-behavior retry or --error-behavior disable (the default is log).
What to build next
You now have a complete, self-contained predictive maintenance loop running inside InfluxDB 3 Core. Some natural extensions:
- Swap in a real model. Replace
compute_health_indexwith a trained regressor or classifier. Install the library withinfluxdb3 install package, load your serialized model at the top of the plugin, and predict per engine. The trigger, the writes, and the alerts don’t change. - Add a notifier. Have the alert branch call an external service like Slack, PagerDuty, email directly from Python. InfluxData also publishes an official notifier plugin you can compose with.
- Use the engine’s cache for stateful detection. Track a rolling baseline or a per-engine trend slope across runs instead of recomputing fleet baselines each time, using the in-memory cache to persist state between executions.
- Lower the latency. Move from a scheduled trigger to a data-write trigger if you need to react the moment a reading crosses a line.
- Browse the official plugin library. InfluxData maintains a public repository of plugins (anomaly detection via MAD, threshold/deadman checks, Prophet forecasting, downsampling, and more) that you can reference directly in a trigger with the
gh:prefix, or copy and adapt.
The broader point is the pattern: with the InfluxDB 3 Processing Engine, the intelligence lives in the database, next to the data, reacting as the data moves. For time-series-heavy domains like industrial IoT and predictive maintenance, that proximity is exactly what you want.
