Microsoft SQL Server Telegraf Plugin logo
Microsoft SQL Server Monitoring Template
Template built by
Telegraf Plugins used:
Included Resources:
  • 1 Telegraf Configuration: mssql-config
  • 1 Dashboards: MSSQL
  • 1 Label: mssql
  • 1 Bucket: mssql
  • 1 Variable: mssqlType
Quick Install
https://raw.githubusercontent.com/influxdata/community-templates/master/mssql/mssql.yml
Microsoft SQL Server monitoring dashboard
Microsoft SQL Server is a popular Relational Database (RDBS) that is used for storing and retrieving data as requested by mission-critical applications. Because it is such an important component of your application, having full insight into how your database is used can help you set up a baseline when analyzing performance. Poor-performing databases could cause serious customer experience issues that will lead to customer dissatisfaction and ultimately to customer abandonment.
When troubleshooting performance issues, baselines help to distinguish between abnormal and routine patterns of behaviors, link cause and effect, and even help make predictions to anticipate potential problems.
Why Microsoft SQL Server monitoring
Microsoft SQL Server is used to store and query data, and it comes with a set of optimization configurations to enhance performance. Users can configure resource use, cache queries, store tables in memory rather than on disk, and control the distribution of CPU, memory and storage by configuring resource pools. Proactive monitoring of how effective these configurations are in your instance will help you establish its health.
Successful database monitoring (regardless of whether you're using Microsoft SQL Server or something else) is of paramount importance to the ongoing maintenance of an application. The ability to quickly and easily find database issues means that you can help your application remain as healthy and as stable (not to mention accessible) as possible, thus guaranteeing a superior experience for your end users. If you're not proactively monitoring your database, even small issues can grow into much more severe ones (like database outages) over time. These outages may even go unnoticed until it's far too late, thus causing your business to lose customers and revenue.
How to use the Microsoft SQL Server Monitoring Template
Once your InfluxDB credentials have been properly configured in the CLI, you can install the Microsoft SQL Server monitoring template using the Quick Install command. Once installed, the data for the dashboard will be populated by the included Telegraf configuration, which includes the relevant MS SQL Server metrics input. Note that you might need to customize the input configuration to better serve your needs if you are running an Azure managed instance. All of this will depend on how your organization is currently running.
To find out more information about environmental variables within the Telegraf configuration, consult the following link.
Key Microsoft SQL Server monitoring metrics to collect
Some of the most important Microsoft SQL Server monitoring metrics that you should proactively monitor include:
  • Uptime
  • Current Queries
  • Active Threads
  • Connections
  • Locks
  • Traffic
  • CPU Usage/Idle
Related Resources
Use the Microsoft SQL Server Telegraf Plugin to monitor the state of your instance.
InfluxDB Cloud on Azure
Get the full Azure experience by collecting your Microsoft SQL Server in an InfluxDB Cloud instance on MS Azure.
Integrated with Azure services and products
InfluxDB integrates with multiple Azure services to streamline accumulation, analysis and actions resulting from time series data.
Scroll to Top
