Postgres Monitoring Template
Telegraf Plugins used:
Included Resources:
- 1 Telegraf Configuration:
'postgres-config'
- 1 Dashboards:
'Postgres'
- 1 Label:
'postgres'
- 1 Bucket:
'postgres'
Quick Install
https://raw.githubusercontent.com/influxdata/community-templates/master/postgresql/postgres.yml
PostgreSQL monitoring dashboard
PostgreSQL, also known as Postgres, is one of the world's most popular relational database management systems. It is a free and open-source relational database management system emphasizing extensibility and SQL compliance. It was originally named POSTGRES, due to its origins as a successor to the Ingres database.
Millions of developers rely on PostgreSQL as their transactional data store to drive application health and decision-making. Developers can use their SQL experience to quickly leverage PostgreSQL's capabilities as a fast, functional, and powerful data resource.
Why monitor PostgreSQL
It is important to monitor your PostgreSQL database — as the transactional store for our important applications — in order to maintain its health. Monitoring your PostgreSQL database helps you identify issues as well as help to continuously improve the database’s performance. The typical way to monitor your PostgreSQL database is to collect metrics from the operating system and the database itself.
How to use PostgreSQL Monitoring Template
Once your InfluxDB credentials have been properly configured in the CLI, you can install the PostgreSQL monitoring template using the Quick Install command. Once installed, the data for the dashboard will be populated by the included PostgreSQL Telegraf configuration, which includes the relevant PostgreSQL Input. Note that you might need to customize the input configuration to better serve your needs, including by specifying a new input value. All of this will depend on how your organization is currently running PostgreSQL.
To find out more information about environmental variables within the Telegraf configuration, consult the following link.
Key PostgreSQL metrics to monitor
Some of the most important PostgreSQL monitoring metrics that you should proactively monitor include:
- IO wait
- CPU
- RAM usage
- Available RAM
- Cached RAM
- Fetch Data
- Returned Data
- Update Data
- Insert Data
- Deleted Data
- Conflicts
- Deadlocks
- Data Used
- Disk Read time
- Disk Write time
- Blocks Read
- Blocks hit
Related Resources
PostgreSQL Telegraf plugin
PostgreSQL Telegraf plugin collects your PostgreSQL metrics to manage performance.
Create your own InfluxDB template
Learn how to create InfluxDB Templates to Make Operations Workflows and Use Cases Scalable and Reliable.
