Industrial AI is a form of physical AI applied to manufacturing, energy, transportation, and infrastructure. Like all physical AI, it runs a five-stage loop on real equipment: sense, decide, act, observe, and adapt. A wrong output can stop a line, damage equipment, or create a safety incident, so industrial models must produce consistent results on identical inputs, trace each decision to its source data, and pass validation against real equipment before running in production. Every stage of that loop depends on a continuous, full-resolution time series record of what equipment actually did. InfluxDB is that record, at the machine and at the hub.
What does industrial AI do?
Industrial AI does four jobs across manufacturing, energy, transportation, and infrastructure, and each one needs something different from the time series data underneath it.
Capability Example What the data layer has to deliver
Prediction Predictive maintenance for robot joints, pumps, and battery modules Full-resolution history of vibration, temperature, current, and voltage for training and retraining
Detection Anomaly detection on a production line, pipeline, or grid segment Low-latency queries on the newest data, so anomalies surface as they occur
Optimization Tuning process setpoints, energy dispatch, and yield Cross-site analytics over long history at consistent granularity
Autonomous decision-making Systems that sense, decide, and act on equipment Millisecond reads at the machine, plus a record of every decision and its outcome
What is industrial AI data?
Industrial AI data is time series data, the timestamped readings that sensors, PLCs, SCADA systems, and machines produce constantly. Its shape sets the requirements for everything downstream. A single Siemens Energy battery module generates more than 100 unique measurements every minute, and the company runs about 23,000 of them across more than 70 sites, so the number of series grows every time the operation does.
Property What it looks like in practice Why it matters for AI
High frequency Sub-second readings from each sensor Downsampling erases the transient spikes that often precede a failure
High cardinality Every asset, sensor, and site is its own series and metadata Series count scales with the operation, so the data layer has to scale with it
Continuous writes Ingest runs around the clock Writes and queries run concurrently without slowing each other
Precise timestamps Millisecond or nanosecond precision in InfluxDB Correlating events across machines and reconstructing incidents depends on exact ordering
What is the difference between industrial AI and physical AI?
Physical AI is the parent category, and industrial AI is a form of it. Physical AI is any system that senses and acts on real-world equipment fast enough to change outcomes in real time. That reaches beyond robots and autonomous vehicles to a vision system rejecting defective parts or a battery storage site adjusting its charge plan to grid conditions. Every industrial AI system is physical AI, but a consumer robot or autonomous passenger vehicle is physical AI without being industrial AI.
Dimension Industrial AI Physical AI
Definition Physical AI applied to industrial operations, held to a standard of repeatability, evidence, and validation AI that senses and acts on real-world equipment fast enough to change outcomes in real time
Scope Manufacturing, energy, transportation, and infrastructure Any system that reads the state of physical equipment and acts on it
Common applications Predictive maintenance, anomaly detection, process optimization, vision-based quality control, battery storage dispatch Consumer robots, autonomous passenger vehicles, and every industrial AI system
Operating loop Sense, decide, act, observe, adapt Sense, decide, act, observe, adapt
Data requirement The same record, captured at the machine and consolidated at the hub A continuous, full-resolution record of what equipment did
The useful line to draw is at the data type. World models and vision-language-action (VLA) systems train on video, 3D scenes, and demonstration data, which belong in stores built for media. InfluxDB sits beside them as the operational telemetry layer, the record that shows whether a system behaves on real equipment the way it did in training.
Why does industrial AI depend on time series data?
Every stage of the physical AI loop writes to or reads from the time series record, and industrial AI runs the same loop.
Loop Stage What Happens What it needs from time series
Sense Read the state of the equipment Writes every sensor reading at full resolution with a precise timestamp
Decide Score current conditions against a model Reads the newest data in milliseconds, with recent history for context
Act Adjust a setpoint, reject a part, or stop the line Writes the action and the conditions that triggered it
Observe Measure what the action did Writes the outcome, in exact order against the action
Adapt Retrain on the outcome Reads long, full-resolution history of conditions, actions, and outcomes from every site
A pilot built on a curated export from one line can prove a model works. Rolling it out to every line in every plant tests the data layer more than the model, because the record has to live in two places with opposite requirements.
Layer Work it performs What it requires
Machine (edge) Signal processing, anomaly scoring, vision inference, and forwarding data to the hub Decisions in milliseconds on limited hardware, with low overhead
Hub (central) Collection, training and retraining, cross-site analytics, and governance Full-resolution history from every site, at a storage cost that makes long retention practical
One system can’t stretch across both. Cloud architecture at the machine adds latency, and a hub built to machine constraints limits training history. Data also degrades in transit, through change-based recording, gateways, and batch exports, with context split across MES, ERP, and CMMS.
Where do data historians fit in industrial AI?
Data historians have been the system of record for plant data for decades, and they still do that job well. OT teams own them, change control protects them, and they log process data reliably for operations and compliance. Industrial AI brings requirements beyond what historians were built for, so many teams run a time series database alongside the historian.
Requirement Historian design focus What industrial AI adds
Retention Compression for efficient long-term logging Full-resolution history, because transient signals feed failure models
Access Tight integration with OT systems SQL and Python access for data science tooling
Scale A defined tag list, expanded with vendor involvement New sensors, lines, and facilities interoperating without a migration project
Query pattern Trends, operator displays, and reports Low-latency inference reads and large training scans
When the historian itself becomes the constraint, replacement is the next step. Scottish Power Energy Networks replaced its legacy historian with InfluxDB to handle the surge in data volume and high-cardinality metadata that came with distributed energy resources. Data historian vs. time series database compares both paths.
How does InfluxDB support industrial AI?
InfluxDB is the time series layer that captures data at the machine, consolidates it at the hub, and serves it to every model that depends on it.
Outcome for the AI team How InfluxDB delivers it Where it shows up
Models train on what actually happened Full-resolution retention on cost-effective object storage Siemens Energy analyzes billions of high-frequency readings from its battery fleet
Anomalies surface as they occur Single-series last-point queries in under 10 ms, and a Last Value Cache for current readings BESS reference architecture on InfluxDB 3
Data scientists build models instead of access pipelines SQL and InfluxQL, Python plugins in the Processing Engine, and the Arrow-based FDAP stack Predictive maintenance plugin built on the Processing Engine
New assets come online without re-architecting Unlimited cardinality, so each sensor, asset, and site is its own series Scottish Power Energy Networks, managing high-cardinality metadata from distributed energy resources
Data stays where operations need it Deployment at the edge, on-premises, in the cloud, and air-gapped InfluxDB 3 Enterprise on Litmus Edge
In a hub-and-spoke deployment, InfluxDB 3 Core or Enterprise runs at the machine or site and InfluxDB 3 Enterprise or Cloud serves as the hub. InfluxDB’s scope is the data layer. Model training and prediction serving stay with the ML tools teams already use, and InfluxDB supplies the data those tools read and stores the outputs they write back.
How do organizations deploy InfluxDB for industrial AI?
Where InfluxDB enters an industrial AI program depends on where the bottleneck sits today.
Role When it fits What InfluxDB handles
Sidecar The historian stays in place under OT change control Full-resolution ingest, low-latency inference queries, and ML tooling access, without touching existing OT operations
Historian replacement A planned modernization of the OT data stack Ingest, storage, and serving, with Litmus or HighByte handling edge connectivity and protocol translation
ML data platform ML team throughput is the bottleneck Feature store, inference substrate, and model output store in one platform
The sidecar is the most common starting point because it leaves OT operations and audit trails untouched, at the cost of one more system to run in the near term. Replacement takes more time and coordination and leaves the operation on an interoperable, long-term stack.
What should teams check before scaling an industrial AI pilot?
Before a pilot goes fleet-wide, five questions show whether the data layer will hold:
  1. Does it keep full-resolution sensor history for training, at a storage cost that makes years of retention practical?
  2. Can decisions at the machine read the newest data in milliseconds on modest hardware?
  3. Does data reach the hub intact, without change-based recording, gateways, or batch exports thinning it along the way?
  4. Can data scientists reach OT data with SQL and Python, without a proprietary SDK?
  5. Can the architecture add sensors, lines, and sites without a migration project?
  6. Can you reconstruct what a system sensed, decided, and did, in exact order?
How do teams move industrial AI from pilot to production?
Industrial AI reaches production by meeting a strict standard of consistency, traceability, and validation, and the evidence for all three lives in time series data. Prediction, detection, optimization, and autonomous decision-making all draw on the same record of what equipment measured and when, captured at the machine and consolidated at the hub. When that record is complete, precise, and fast to query, a model proven on one line can run on every line in every plant. The five questions above show whether a data layer is ready for that step, and InfluxDB 3 is built to answer yes to each of them.
Frequently asked questions
Is industrial AI part of physical AI?
Yes. InfluxData treats physical AI as the parent category and industrial AI as a form of it. Physical AI covers any system that senses and acts on real-world equipment fast enough to change outcomes in real time, from robots and autonomous vehicles to vision systems that reject defective parts. Industrial AI applies the same sense, decide, act, observe, and adapt loop to manufacturing, energy, transportation, and infrastructure, and is held to a higher standard of repeatability, evidence, and validation. Every industrial AI system is a physical AI system, but a consumer robot or autonomous passenger vehicle is physical AI without being industrial AI.
Why do industrial AI pilots struggle to reach production?
Industrial AI pilots often stall at the data layer. A pilot can train on a curated export from one line, but production needs full-resolution data from every asset, held in two places with opposite requirements: millisecond decisions on modest hardware at the machine, and years of cross-site history at the hub. Data also degrades between the two through change-based recording, gateways, and batch exports. Closing that gap takes a time series layer that runs at both the machine and the hub and keeps the record at full resolution end to end.
Can you use a data historian for machine learning?
Data historians remain the system of record for plant data, but they were built for logging and reporting, and often compress or downsample to save space. Machine learning needs the live feed and full-signal history those designs leave out. Many teams keep the historian in place and stream the same data in parallel to a time series database such as InfluxDB, which keeps full resolution and opens the data to SQL and Python. This augmentation approach adds AI capability without disrupting existing OT operations or audit trails.
What sensor data does predictive maintenance need?
Predictive maintenance needs continuous, timestamped readings such as vibration, temperature, current, voltage, and pressure from each asset over long periods, since models learn failure patterns from how those signals change over time. Full-resolution history matters because summarized data can smooth away the early signs of wear. Olympus Controls, for example, tracks current and temperature on the joints of industrial robots in InfluxDB to predict maintenance windows.
Does InfluxDB train or serve AI models?
InfluxDB is the data layer for industrial AI, so model training and prediction serving stay with ML tools. It acts as the feature store for training data, the inference substrate for low-latency queries on live data, and the store for model outputs. The InfluxDB 3 Processing Engine also runs Python plugins inside the database, which teams use for safety and alerting logic close to the data.
Can InfluxDB run in air-gapped industrial environments?
Yes, InfluxDB 3 runs in air-gapped deployments as well as at the edge, on-premises, and in the cloud. InfluxDB 3 Enterprise adds high availability, read replicas, and multi-region durability for air-gapped sites and anywhere an outage is a safety concern.
