‹ Plugins / River Forecaster
Data-write
River Forecaster
Most forecasting setups demand a separate pipeline. The River Forecaster plugin for InfluxDB 3 eliminates that entirely: a single WAL trigger learns incrementally from every incoming observation, produces multi-step-ahead forecasts automatically, and writes predictions back to your database as queryable time series data. No batch retraining, no external serving layer, no separate configuration per series.
Configuration
Arguments can be passed inline (space-separated lists) or via TOML config file (native TOML lists). Parameter names are the same in both modes.
Argument Required Default Description
include_tables Yes — Space-separated tables to forecast (e.g., system_cpu system_memory). In TOML config use a list.
include_fields No (all) Space-separated fields to forecast (e.g., idle used). Omit to use all numeric fields. In TOML config use a list.
string_fields No (none) Space-separated string column names that should be treated as fields, not tags. All other string columns become tags. In TOML config use a list.
max_series No 50 Max unique series to track (LRU eviction)
min_observations No 30 Minimum observations before forecasting
default_horizon No 12 Fallback horizon if the model’s own write_interval estimate is unavailable
forecast_target_seconds No 3600 Target forecast window for auto-horizon
snarimax_p No 0 (auto) SNARIMAX autoregressive order. 0 = auto-tune from write frequency (~1h lookback, clamped 4-30)
snarimax_d No 1 SNARIMAX differencing order
snarimax_q No 1 SNARIMAX moving average order
calibration_count No 30 Observations buffered before finalizing SNARIMAX p (only used when snarimax_p=0). Larger = more reliable interval estimate, longer warm-up.
log_forecasts No false Log forecast details
checkpoint_interval_seconds No 1800 Seconds between model checkpoints to the database
max_checkpoint_age_hours No 24 Ignore checkpoints older than this when restoring
min_checkpoint_observations No 10 Skip checkpointing models with fewer observations than this (avoids persisting cold-start models)
config_file_path No — Path to TOML config file
Ready to get started?
Download InfluxDB 3 and have River Forecaster running in minutes.
