‹ Plugins / Simple Data Replicator
Scheduled Data-write
Replicating data between InfluxDB 3 instances shouldn’t mean writing your own retry logic and queue management. The Simple Data Replicator Plugin does it for you, streaming data to a remote instance on a schedule or on every write, with compressed buffering, automatic retries, and field-level filtering and renaming built in. Point it at a source and a destination, and it keeps data flowing even when the network doesn’t cooperate.
Configuration
Plugin parameters may be specified as key-value pairs in the --trigger-arguments flag (CLI) or in the trigger_arguments field (API) when creating a trigger. This plugin supports TOML configuration files, which can be specified using the config_file_path parameter; values in the file override the arguments passed to the trigger.
Plugin metadata
This plugin includes a JSON metadata schema in its docstring that defines supported trigger types and configuration parameters. This metadata enables the InfluxDB 3 Explorer UI to display and configure the plugin.
Scheduler mode parameters
Multi-value arguments (excluded_fields, field_renames) use delimited strings on the CLI and native TOML types (lists/tables) in a config file.
Argument Description Required Example (CLI) Example (TOML) Default
host Remote InfluxDB host URL. Default scheme http, port 8181. true example.com host = "example.com" None
remote_token Remote InfluxDB API token. Falls back to REMOTE_INFLUXDB_TOKEN env var. false apiv3_AuHk... remote_token = "apiv3_AuHk..." None
database Remote database name. true remote_db database = "remote_db" None
source_measurement Measurement to replicate. true home source_measurement = "home" None
window Time window per job. Format number:unit (s, min, h, d, w). true 1h window = "1h" None
unique_file_suffix Unique suffix for the queue file to avoid conflicts. true abcd1234 unique_file_suffix = "abcd1234" None
max_size Maximum size for the queue file in MB. Integer ≥ 1. false 1024 max_size = 1024 512
verify_ssl Whether to verify SSL certificates when connecting via HTTPS. false false verify_ssl = false true
max_retries Maximum number of retries for write operations. Integer ≥ 1. false 5 max_retries = 5 3
queue_flush_chunk_size Line-protocol entries sent per remote flush request. Integer ≥ 1. false 1000 queue_flush_chunk_size = 1000 500
excluded_fields Fields and tags to exclude. CLI: space-separated. TOML: list. false co location excluded_fields = ["co", "location"] None
target_table New name for the measurement in the remote database. false home2 target_table = "home2" source_measurement
field_renames Field renames. CLI: old:new pairs separated by space. TOML: table. false temp:temperature field_renames = {temp = "temperature"} None
offset Time offset to apply to the window. Format number:unit (s, min, h, d, w). false 10min offset = "10min" 0
config_file_path Path to the TOML config file. Absolute, or relative to PLUGIN_DIR. false config.toml — None
Data write mode parameters
Multi-value arguments (tables, excluded_fields, tables_rename, field_renames) use delimited strings on the CLI and native TOML types (lists/tables) in a config file.
unique_file_suffix Unique suffix for the queue file to avoid conflicts. true wxyz5678 unique_file_suffix = "wxyz5678" None
tables Tables to replicate; all tables if omitted. CLI: space-separated. TOML: list. false home home2 tables = ["home", "home2"] None
excluded_fields Fields/tags to exclude per table. CLI: table:f1|f2 blocks separated by space. TOML: table of lists. false home:co|location home2:temp excluded_fields = {home = ["co", "location"], home2 = ["temp"]} None
tables_rename Table renames. CLI: old:new pairs separated by space. TOML: table. false home:home2 office:office2 tables_rename = {home = "home2", office = "office2"} None
field_renames Field renames per table. CLI: table:old=new\|old=new blocks separated by space. TOML: nested table. false home:temp=temperature|hum=humidity [field_renames]
home = {temp = "temperature", hum = "humidity"}
None
Authentication
The remote API token is read from the remote_token argument first; if it is not set, the plugin falls back to the REMOTE_INFLUXDB_TOKEN environment variable. If neither is provided, the plugin returns an error.
File path resolution
The config_file_path and the queue directory follow the same resolution logic:
  • Absolute paths are used as-is.
  • Relative paths are resolved from the PLUGIN_DIR environment variable. If PLUGIN_DIR is not set, the plugin falls back to INFLUXDB3_PLUGIN_DIR and then the parent of VIRTUAL_ENV.
If none of these are available, the plugin returns an error.
Example TOML configuration
Data requirements
The plugin assumes the table schema is already defined in the local database; it relies on this schema to retrieve the field and tag names required for processing. The remote target database must already exist.
Ready to get started?
Download InfluxDB 3 and have Simple Data Replicator running in minutes.
