Summary
Automotive manufacturers face rising costs and scaling limits with per-tag-priced data historians as sensor counts and sampling rates grow. Instead of rip-and-replace, manufacturers are augmenting traditional data historians by routing new telemetry to InfluxDB (via Telegraf or Litmus or consolidating siloed historians, while the historian continues handling SCADA and regulatory data.
Table of Contents
A modern vehicle assembly line generates more time-stamped telemetry before lunch than most data historians were built to hold: weld temperatures, torque readings, and vibration traces from every robot, torque tool, vision system, and test stand, and on most historians, each signal carries its own line-item cost because the systems are still priced per tag. That model was fine when data was scarce; it breaks down as OEMs and Tier 1 and Tier 2 suppliers add sensors, stations, and higher sampling rates every year, turning instrumentation into a budgeting exercise before it becomes a visibility gain.
The instinct is to rip out the historian and start over. On a validated, IATF 16949-certified production line, that’s rarely realistic: historians from vendors like OSI PI/AVEVA, Wonderware, GE, and Honeywell are wired into SCADA systems, PLCs, robot controllers, and distributed control systems that keep the line running, and replacing that layer risks a stoppage that cascades into missed takt, JIT penalties, and downstream OEM shutdowns within hours. InfluxDB, a purpose-built time series platform, takes a more pragmatic path: augmenting the historian instead of replacing it.
Why data historians are hitting a wall in Industry 4.0
Data historians were built for Industry 3.0: one plant, one shift pattern, one set of tags, running on-premises with modest data volumes. They’re still good at that job. What they weren’t built for is Industry 4.0, where interconnected devices, IIoT sensors, and cloud-native systems generate volume, variety, and velocity of telemetry that legacy architectures never had to handle.
Three problems show up consistently as manufacturers try to close that gap.
Vendor lock-in. Historians are proprietary and tightly controlled by their vendors. Licensing, upgrades, and even adding a tag for a new robot sensor or launch program often require vendor involvement, which locks plants into a single roadmap at a time when margins are already under tariff and EV-transition pressure.
Scalability and cost. Historians can often handle a surprising volume of tags within a single plant. The real limit is cost, not raw capacity. Adding hundreds of robots, weld guns, and sensors across a modern line means more hardware and more per-tag licensing, and that compounds further at multi-plant scale, where consolidating data across sites becomes both harder and more expensive than adding capacity within one plant.
Real-time limitations. Legacy historians weren’t designed for predictive models or AI/ML workloads on high-frequency signals like torque, weld current, or robot vibration. Pulling that data out usually means batch exports or custom connectors, which delay insight and lead to avoidable downtime. In an assembly environment running on takt time measured in seconds, even a small lag can mean a missed beat, stalled production, or overtime.
Ingest, cardinality, and query range at Industry 4.0 scale
At Industry 4.0 data volumes, three things decide whether a platform can keep up: how much it can ingest without slowing down, how much metadata per time series is collected, and how far back it can query without switching to a separate system. A time series platform built specifically for this workload, like InfluxDB, is engineered to process millions of data points per second from diverse sources without performance degradation, using indexing that holds up as cardinality grows into the millions.
| Characteristic | Data historian | Time series platform |
| Ingest volume | Thousands of points/second from fixed sources; can be overwhelmed by modern telemetry | Millions of data points per second from diverse sources, no performance degradation |
| Cardinality | Performance degrades as unique tags grow | Advanced indexing built for millions of unique time series |
| Query range | Fast on recent data; long-term history is slow or needs a separate system | Real-time and historical data unified for queries across any time range |
| Interoperability | Proprietary, closed; requires custom connectors | Open standards and APIs (SQL, REST, Python, Grafana, Power BI) |
| Cost model | Per-tag licensing | Compute-based, no per-tag penalty |
Interoperability matters just as much as raw throughput: a platform that plugs directly into the tools industrial teams already use, like Grafana, Power BI, Python, and AI/ML pipelines, avoids the expensive custom connectors historians are known for. InfluxDB is built on open standards and APIs for exactly that reason.
How InfluxDB augments a data historian
InfluxDB’s role isn’t to take over what the historian already does well. It’s to take on what the historian was never designed to handle, while the historian keeps running SCADA historization, GxP and regulatory data, and the operator dashboards teams already trust.
There are two common ways manufacturers deploy InfluxDB alongside a historian.
Parallel feed. New instrumentation, robots, stations, and launch programs get routed to InfluxDB instead of adding to the historian’s tag count. Telegraf, InfluxData’s open source data collection agent with plugins for OPC-UA, MQTT, and Modbus (the same protocols already used to talk to robot controllers and weld cells), streams that data into InfluxDB with little to no latency. The historian stays in the system of record; InfluxDB handles the dashboards, anomaly detection on weld and torque signatures, and predictive maintenance work that would otherwise wait on the historian’s licensing terms.
Consolidation. Many OEMs and Tier 1 suppliers run several historians, sometimes one per plant, sometimes one per acquired site, that weren’t built to talk to each other. InfluxDB sits downstream of those systems as a central operational layer, unifying siloed feeds into a single source of truth that Grafana or a similar visualization tool can present as one dashboard, shortening launch reviews, quality audits, and warranty investigations that currently require reconciling conflicting data across plants.
For plants running a wider mix of PLCs, CNCs, and proprietary equipment than Telegraf’s protocol plugins cover on their own, InfluxData partners with Litmus, an industrial data operations platform with 250+ prebuilt connectors for OT systems like PLCs, SCADA, and CNC machines. Litmus normalizes and contextualizes raw machine signals at the edge, tagging them with asset, facility, and production-line metadata, while InfluxDB handles ingestion, real-time analysis, and long-term storage of that contextualized telemetry, locally at the plant and replicated to a central hub for fleet-wide visibility.
Automotive and industrial manufacturers already running InfluxDB
A few companies already running InfluxDB at automotive scale show what historian augmentation delivers in practice.
Toyo Tires replaced a manual system for quality control and anomaly detection that couldn’t reliably catch defective tires before they left the line, or support the 20-year data retention its audit requirements demand. With InfluxDB Enterprise, Toyo now runs real-time and long-term analysis for quality issues cost-effectively, and has scaled from a single plant in Serbia monitoring 100 machines to as many as 1,000 machines across multiple locations.
American Axle & Manufacturing, a Tier 1 automotive and mobility supplier with nearly 85 facilities in 18 countries, runs the TIG stack (Telegraf, InfluxDB, and Grafana) across its enterprise data infrastructure, including monitoring 78 file servers at remote manufacturing sites and database performance alerting. “The combination of Grafana, InfluxDB, and Telegraf is a winning one,” said Stewart McKenna, Systems Administrator at AAM. “It’s really easy to come up with use cases, and the ease of displaying the data to leadership is wonderful.”
Getting started doesn’t require a disruptive overhaul: route new telemetry, one line, one plant, or one launch program at a time to InfluxDB instead of the historian’s tag count, and expand once that pilot proves the case. InfluxData’s full guide, Scaling Time Series for Automotive Manufacturing, covers deployment architectures and a step-by-step path for scaling across a plant network. Manufacturers ready to test it against their own telemetry can request a proof of concept with InfluxData.
