Table of Contents
Automotive manufacturing generates data at several operating cadences. Sensors and controllers emit measurements continuously. Equipment and line states change as events. Production and quality systems add context at the part, batch, shift, and plant level. Together, these records describe how a manufacturing process behaves over time.
That data can support plant visibility, investigations, scrap reduction, condition monitoring, and longer-term comparison, but only if the storage and query layer can keep up with the workload. InfluxDB is a practical fit for these types of workloads because it is optimized for continuous, time-stamped data and can process, retain, and query it without requiring every system around it to be redesigned.
Why automotive data is a time series workload
A time series workload is, at its core, any data where you primarily store, query, and analyze it by looking at when it happened and how it progressed from one state to another.
A temperature measurement in a time series workload never exists in isolation. When a device overheats, you ask how long it took to heat up, whether it had opportunities to cool down, and what that looked like over the span of five, ten, or fifty minutes. The same principles can apply to vibration, torque, current, pressure, flow, cycle state, machine availability, inspection results, alarms, and many other signals generated during vehicle and component production.
Queries are written to understand what changed during a particular interval, whether a condition persisted, how one shift compared with another, or how several signals behaved around a production or quality event. Those queries tend to start with a filter on timestamps to the relevant window in which questions are being asked, narrow the data to the relevant equipment or process, and then aggregate, compare, or retrieve the latest values.
The write pattern of time series data is often distinctive, too. Sensors create readings at a regular cadence, so new data points arrive continuously, almost exclusively as appends to the database, with few or no updates or edits to historical rows.
The same data also has value at very different time scales. Recent, high-resolution telemetry can support detailed investigations. Longer-range summaries can support plant management, capacity planning, process comparison, forecasting, and cross-plant visibility. Keeping every full-resolution observation may be difficult to justify, but reducing everything to hourly averages at ingestion time throws away information before anyone knows whether it will matter.
This combination of continuous writes, time-bounded reads, multiple resolutions, and changing retention value is what makes automotive telemetry a time series workload.
Automotive systems also contain plenty of data that doesn’t fit this description. Bills of material, work orders, user accounts, inventory records, and transactional production data may belong in an MES, ERP system, or relational database. InfluxDB is designed to operationalize telemetry, and it’s part of a well-orchestrated tech stack.
Why use a time series database?
Any relational database (or even Excel) can store time-stamped measurements. The question is: how efficiently, effectively, and easily can they handle a time series workload, and can they scale? We already have a blog on this topic that explains the advantages of time series databases, and it’s a good place to start if you want to understand their key advantages.
To summarize for automotive telemetry: InfluxDB most efficiently handles high-volume ingestion and time-oriented querying, while database- and table-level retention lets you control how long each data type remains available. A high-volume raw table can have a shorter retention period than a cleaned or downsampled table in the same database, and because InfluxDB 3 is designed and built for low-cost object storage, data costs stay low. Even better, all tables are very efficiently compressed, minimizing the footprint in object storage and lowering costs.
The Last Value Cache addresses another common query pattern: retrieving the newest value, or last few values, for each series. That is useful for current-state views where repeatedly scanning recent history would be unnecessary work.
These features map directly to the shape of automotive manufacturing data workloads, which ingest continuously, query by time, keep recent detail, summarize older data, and serve current state efficiently. This makes a time-series database like InfluxDB the only cost-effective, performant, scalable choice for high-volume, time series workloads.
A reference architecture for automotive manufacturing
Rather than talking about it at a high level, it may be easier to show you how the architecture works in action.
The InfluxDB 3 automotive manufacturing reference architecture is a runnable example of an automotive time series pipeline. It uses Docker Compose, InfluxDB 3 Enterprise, Processing Engine plugins, and a small web UI:
git clone https://github.com/influxdata/influxdb3-ref-auto-manufacturing.git
cd influxdb3-ref-auto-manufacturing
make up
On first boot, the setup asks for an email address and sends an InfluxDB 3 Enterprise license-validation link. After validation, this stack begins generating and processing the simulated plant data, and you can see it by opening the UI at:
http://localhost:8080
The repository installs InfluxDB-approved plugins, creates tables and triggers, runs the processing chain, and exposes raw, processed, downsampled, and forecast data through the UI. It also demonstrates isolated station pipelines and a Last Value Cache for current-state views.
Make sure you read the production notes before using it as a deployment template. The demo is single-node, uses a file-backed object store, shares an admin token between services, and does not enable TLS inside the Compose network. Production requires scoped service tokens, TLS, durable object storage, monitoring, backup planning, and an appropriate multi-node topology. One easy-to-miss detail: create source tables before registering WAL triggers, or the triggers may never fire.
The repository’s most useful pattern is its separation of concerns. You can replace the signal generator with an OPC UA, historian, or gateway feed and keep the downstream stages. You can change the filter without rewriting the dashboard, or you can change retention without touching the PLC.
Building on the reference architecture
Obviously, this is a reference architecture, and it’s meant to be the first step towards building the architecture for your deployment. The most obvious first change to make is replacing the signal generator with an actual data source.
The repository is deliberately structured so that this happens at the input boundary. Telegraf’s OPC UA input can collect data from an OPC UA server and write it to InfluxDB. An industrial integration platform such as Litmus or HighByte can write line protocol through the InfluxDB write API. A historian or existing plant application can also become the source if it already exposes the required data. Downstream processing stages don’t need to know which route the points took to get there.
From there, the work becomes signal-specific.
A regular time grid may be necessary when several sensors need to be aligned or when an algorithm expects a stable sample rate. It may add little value for an event stream. Gap filling should be bounded and explicit, and ideally preserve enough metadata to distinguish observed values from generated ones. Some gaps should remain gaps because the absence of data is useful information, as it can indicate that certain systems were paused or sensors stopped generating readings.
Filtering requires similar care. A filter that cleans up a slowly changing booth-temperature signal may be inappropriate for current, vibration, pressure, or torque. Before filtering a production stream, test the filter against the events engineers actually need to preserve. Keep the raw signal long enough to compare the processed output against it.
Downsampling is another place to be deliberate. Whether you use an average, minimum, maximum, or median, downsampling necessarily entails losing some information. Fortunately, the Downsampler plugin can generate several calculations for the same source measurement. Useful output might include an average for long-term trends, a maximum for threshold analysis, and a count to show whether the interval contained the expected number of observations.
Retention follows the same logic. Raw telemetry can remain available for the period in which detailed investigations are likely. Intermediate processing tables may only need to exist long enough to support the next stage. Cleaned or downsampled data can remain available for longer-range analysis. InfluxDB’s table-level retention overrides make it possible to apply those policies within the same database, so that data can flow from maximal-resolution fresh tables into lower-resolution longer-term storage. This ensures all data is available when needed, without paying to store immense volumes of data that will only be used for sporadic historical analysis.
Finally, the local deployment needs ordinary production hardening. The repository’s architecture notes cover moving from local files to S3, Google Cloud Storage, or Azure Blob Storage; separating ingest, query, compaction, and processing roles; using scoped tokens for individual services; and enabling TLS across trust boundaries. Plugins should also have version control, automated tests, resource limits, and a repeatable deployment process. Running Python inside the database removes some infrastructure, but it’s still production code.
Augmenting an existing automotive data stack
Many automotive environments already have control systems, historians, manufacturing applications, quality systems, and enterprise analytics infrastructure. There’s no need to displace them before evaluating InfluxDB. Similarly, the justification for adding InfluxDB doesn’t depend on proving that the historian, warehouse, or relational database is bad. It depends on whether a specialized time series database can serve a particular workload more efficiently.
A useful entry point is to start bounded, picking a specific task or domain where InfluxDB may be worth leveraging. Mirror data from that domain into InfluxDB, but allow your existing systems to remain authoritative. Because InfluxDB 3 uses SQL, you can likely run the same queries across your existing system and InfluxDB at the same time, and just like that, you’re testing which system is more efficient. How fresh is the data? What’s the query latency, especially when you’re leveraging the Last Value Cache?
Once it’s running, you can see what else InfluxDB unlocks for you. Use the Processing Engine with ML plugins to detect anomalies and generate forecasts that help with predictive maintenance. Hook into the InfluxDB MCP server to power your AI agents with your data. The database is the backbone, and what you build on top of it is where you truly begin to derive value.
Measure sustained ingestion, storage consumption at each resolution, query latency for real investigation patterns, and operational overhead. Ask yourself how useful the resulting analysis, forecasts, and downstream tools you built are. A bounded evaluation with representative data gives you evidence from your own workload, which is what truly matters for your use case.
Bringing it all together
Automotive telemetry has the defining characteristics of a time series workload: continuous writes, time-bounded queries, value at multiple resolutions, and a useful lifetime that changes as the data ages.
InfluxDB provides a specialized solution for that workload. The automotive reference architecture makes the design concrete by showing how ingestion, resampling, gap filling, filtering, downsampling, forecasting, caching, and retention can fit together without becoming one inseparable pipeline. Once you’ve got the data flowing, you’ll unlock new capabilities to maximize the value you get from your data, driving efficiency and better data-driven results.
Get started with a free trial of InfluxDB 3 Enterprise, and try it out today.
