BESS telemetry monitoring is the practice of collecting timestamped measurements from a battery energy storage system (BESS) and its power conversion, control, metering, and environmental equipment, then using them to monitor conditions, investigate incidents, analyze performance, and compare assets across sites. A time series database such as InfluxDB stores that telemetry downstream of the systems that control the battery and serves it to dashboards, engineering tools, analytics, and AI.
What is BESS telemetry?
BESS telemetry is the stream of timestamped measurements that describes how batteries, inverters, control systems, meters, and supporting equipment are operating.
Telemetry type Examples What it tells operators
Battery Cell and module voltage, current, temperature, State of Charge, State of Health How batteries are operating and changing over time
Power conversion Inverter power, current, voltage, operating state How electrical power is being converted and delivered
Energy management Dispatch state, charge/discharge commands, operating mode How the system is being scheduled and optimized
Plant supervision SCADA alarms, equipment states, site conditions What is happening across the facility
Metering and environment Grid measurements, ambient temperature, environmental conditions The external conditions surrounding BESS operation
Why use a time series database for BESS telemetry?
BESS telemetry is fragmented by design, and a purpose-built time series database brings it into one timestamped layer where it can be queried together.
Each system supplies a different part of the operational picture, and the volume is large: a single utility-scale site can produce more than 50,000 distinct signals from cells, inverters, and meters. Understanding one event at one site may require data from the BMS, PCS, EMS, SCADA, meters, and environmental systems. Across a fleet, that fragmentation multiplies across sites, vendors, configurations, and operating conditions.
A common time series layer helps teams investigate incidents faster, analyze performance and degradation over time, compare assets across sites, and manage growing fleets more efficiently. For the operational cost of data silos in more detail, see Unifying Telemetry in Battery Energy Storage Systems.
Designing the telemetry layer
Once telemetry shares one layer, four design choices decide how useful it is: how each measurement stays identifiable, where the layer sits next to the control systems, how data arrives, and how long it is kept.
Keeping asset context in every measurement
Every measurement needs to carry its source, so similar readings from different racks, cells, and sites stay distinguishable while remaining queryable together.
InfluxDB stores identifying metadata as tags, measured values as fields, and a timestamp for each point. The InfluxDB 3 BESS reference architecture shows the pattern with cell data identified by pack_id, module_id, and cell_id, and voltage and temperature_c as the measured values.
Element Role BESS example
Tags Identify the source of the measurement Site, rack, module, cell
Field Holds the measured value Cell temperature
Timestamp Records when the measurement occurred Time of the reading
With consistent identifiers, an engineer can select one rack’s temperature readings during an incident, compare them with neighboring racks, and check equivalent equipment at other sites. The same identifiers can serve as cache keys for current-state queries (see the real-time section below).
Where does InfluxDB fit alongside the control systems?
InfluxDB sits in the telemetry data layer, downstream of the systems that monitor and control the BESS, and does not replace them.
System Responsible for Relationship to InfluxDB
BMS Battery safety and health InfluxDB stores its cell-level telemetry; the BMS keeps safety and protection
PCS Power conversion InfluxDB stores inverter power, state, and faults
EMS Optimization and dispatch InfluxDB stores dispatch state and charge/discharge commands
SCADA Plant-level supervision InfluxDB stores alarms and equipment states
That separation lets teams build a common telemetry layer without replacing the specialized systems that operate the asset.
InfluxDB can also run monitoring logic on telemetry as it arrives. The Processing Engine runs Python plugins inside InfluxDB 3 to detect anomalies, raise alerts, and compute derived values, and the reference architecture includes a thermal-runaway detection plugin. These are monitoring and alerting functions. Protective shutdowns and safety interlocks stay in the BMS.
Open-connectivity
Getting BESS data into InfluxDB
Telemetry reaches InfluxDB through collectors, industrial protocols, APIs, and message brokers, depending on what is already deployed at the site.
Source Typical protocols
BMS CANbus, Modbus TCP, or vendor-specific RPC
PCS / inverters Modbus TCP, SunSpec, or vendor APIs
SCADA / EMS OPC UA, MQTT, or Modbus
Telegraf is the usual collection layer, run at the edge or in the DMZ with OPC UA, Modbus, and MQTT plugins. It normalizes readings into a consistent format and buffers locally so a connectivity gap does not cost data. For OPC UA equipment, the InfluxDB 3 OPC UA plugin connects to the server and writes directly into the database, one fewer process to operate. Data can also arrive through message brokers such as Kafka.
The Building Time Series Pipelines for BESS webinar covers the challenges that tend to follow: ingest rate, backfill handling, and long-term storage.
Deciding how long to keep telemetry
Retention should follow how each class of telemetry is used, and InfluxDB can keep full-resolution history for years rather than forcing early downsampling.
Operational applications mostly need recent measurements. Reliability, engineering, analytics, and AI workloads often need months or years of history to study degradation, efficiency, and recurring operating patterns. The BESS solutions page describes storing years of full-resolution telemetry in object storage with high-ratio compression, so analytics and machine learning keep the detail they need.
Downsampling remains a choice. A Processing Engine downsampler plugin can, for example, convert 10 ms raw data into one-minute averages for long-term storage, as described in Optimizing BESS Operations.
Putting the telemetry to work
With the layer in place, the same data serves several jobs, from live monitoring to fleet-wide comparison.
What teams do with the telemetry
Workload What it does
Operational monitoring Shows recent battery, inverter, alarm, and operating-state information
Reliability and troubleshooting Correlates telemetry across systems to investigate faults and abnormal behavior
Performance analysis Examines efficiency, thermal behavior, cell divergence, and other operating characteristics
Degradation analysis Tracks how batteries and other equipment change over weeks, months, or years
Fleet analytics Compares similar assets, sites, equipment, and operating conditions
Engineering and modeling Uses retained telemetry to develop, validate, and evaluate analytical models
Applications and AI Queries telemetry and derived values for downstream analysis and workflows
Correlating events across systems
A measurement is most useful when compared with earlier readings and with related measurements from the same time window.
An elevated rack temperature does not explain itself. An engineer compares the temperature trend with cell voltage, battery current, inverter power, dispatch state, SCADA alarms, and ambient temperature before, during, and after the event. Preserved timestamps and asset context make that comparison possible, and with the relevant systems in one time series layer, teams can query it directly in SQL instead of reconstructing the incident from several tools first.
The result helps separate an isolated sensor reading from a persistent operating condition, an equipment issue, or behavior affecting other parts of the system.
Using the same telemetry for real-time and historical analysis
From an operations perspective, recent telemetry supports awareness of current conditions across batteries, inverters, and supporting systems.
Historical telemetry answers a different set of questions.
A live reading may show that one cell is hotter than its neighbors. Historical telemetry can show whether that difference is new, persistent, seasonal, or associated with particular charge and discharge conditions.
Reliability and engineering teams may examine weeks or months of voltage, temperature, State of Charge, State of Health, power, and operating-state data to investigate degradation, efficiency, thermal behavior, cell divergence, and recurring operating patterns.
AI and analytical workflows may also use both modes. Historical telemetry provides examples for developing and evaluating models, while recent measurements provide inputs to deployed analytical or anomaly-detection workflows.
InfluxDB 3 Enterprise supports both current and historical workloads. For example, its Last Value Cache can accelerate access to recent values for selected fields and series. An application could retrieve a recent battery temperature or voltage value while engineers query the retained history of that same measurement to investigate trends and events. See The “Now” Problem: Why BESS Operations Demand Last Value Caching for setup.
Comparing performance across sites
Consistent asset context lets teams move from one rack to the whole fleet using the same query pattern.
Each site may have its own BMS, PCS, EMS, SCADA system, and meters, and sites can differ in vendor, configuration, capacity, operating strategy, and environment. Because every measurement carries the same site, rack, module, and cell identifiers, equivalent telemetry stays comparable across those differences. Teams can compare thermal behavior, efficiency, cell divergence, inverter performance, and operating patterns across sites, and check whether behavior seen in one rack appears in similar equipment elsewhere.
This works at scale in production. Siemens Energy uses InfluxDB to monitor about 23,000 battery modules across more than 70 sites, and ju:niz Energy streams thousands of data points per second from its large-scale battery storage systems.
Scaling from one site to a fleet
The same design has to hold as sites multiply, which raises two questions: whether workloads share one layer, and where that layer runs.
Why use a shared layer instead of separate stores?
A shared layer avoids duplicating pipelines and storage for every dashboard, application, and site, and keeps the detail needed to investigate a problem.
Separate stores for monitoring, engineering, analytics, applications, and individual sites duplicate ingestion pipelines, storage, integrations, and operating processes. They also fragment the data: a summarized analytical dataset may drop detail needed during an incident, while an operational monitoring platform may keep too little history to tell whether a condition is unusual.
With one shared layer, each workload queries the time range and level of detail it needs from the same telemetry. Dashboards, engineering tools, analytical applications, and AI workflows read the same data instead of requiring another copy for every new use case.
Choosing a site, central, or hybrid topology
InfluxDB does not require one topology: it can run at a single site, centrally across a fleet, or in both places.
Topology Where telemetry lives Fits when
Site-level At each site, close to the assets Local access, resilience, or latency matters
Central One deployment collecting from multiple sites Fleet monitoring, engineering, analytics, and comparison are the priority
Hybrid Full-resolution data at the site, selected data forwarded to a fleet-level platform Teams need local operation and fleet-wide analysis
The reference architecture describes a common hybrid shape: Telegraf at each site ingests BMS, PCS, SCADA, and EMS data; InfluxDB 3 Enterprise at the edge stores full-resolution data and runs local logic through the Processing Engine; and replication forwards rolled-up data to a central InfluxDB 3 Enterprise cluster for fleet analysis. Scale can start small too: a single InfluxDB 3 Core instance can serve one site, growing to a multi-node Enterprise cluster as the fleet grows.
Connectivity, latency, resilience, governance, retention, ownership, and cost determine which topology is appropriate.
Frequently asked questions
What BESS measurements are commonly stored in a time series database?
Common BESS time series include cell and module voltage, current, temperature, State of Charge, State of Health, power, inverter state, alarms, meter readings, dispatch signals, and environmental conditions.
Identifiers such as site, rack, module, cell, or inverter provide the source and asset context needed to distinguish similar measurements across a system or fleet.
Does InfluxDB replace the BMS, PCS, EMS, or SCADA system?
No. InfluxDB is part of the telemetry data layer, not the control plane.
The BMS retains responsibility for battery safety and health, the PCS manages power conversion, the EMS handles optimization and dispatch, and SCADA provides plant-level supervision.
InfluxDB stores and serves their timestamped telemetry so applications and teams can work with the data together.
Can telemetry from the BMS, PCS, EMS, and SCADA be stored together?
Yes. Once their measurements have been collected as timestamped telemetry, they can be stored in the same time series layer while retaining metadata that identifies their source and asset.
This allows teams to correlate events across systems without removing the functional boundaries between them.
Does InfluxDB support both current and historical BESS telemetry?
Yes. Recent telemetry can support operational monitoring and applications, while retained historical telemetry can support incident investigation, performance analysis, degradation analysis, fleet comparison, engineering, and modeling.
Teams can configure retention according to how long different measurements need to remain available.
Can the same BESS telemetry support dashboards, analytics, and AI?
Yes. The same timestamped measurements can support different downstream consumers when the telemetry layer preserves the required resolution, history, and asset context.
Dashboards may focus on recent values, engineering workflows may examine particular incidents or long-term trends, and analytics or AI systems may use longer histories for comparison, modeling, and analysis.
Can InfluxDB support both an individual BESS site and an entire fleet?
Yes. InfluxDB can operate at an individual site, centrally across multiple sites, or in an architecture combining site-level and fleet-level telemetry layers.
The appropriate topology depends on factors such as connectivity, latency, resilience, governance, retention, ownership, and operational requirements.
