Table of Contents
Observability is the ability to understand a software system’s internal behavior by examining the telemetry it produces. Teams use correlated metrics, logs, and traces to investigate failures, explain performance changes, and assess user impact. An observable system provides enough context to check system health and investigate unexpected behavior across applications, infrastructure, and dependencies.
What is observability?
Software observability helps engineers ask questions about a system and investigate them using evidence from its outputs. A dashboard can reveal a rise in errors; useful telemetry also helps identify the affected services, requests, dependencies, and changes.
The term comes from control theory, where observability concerns inferring a system’s internal state from its outputs. In software engineering, the concept guides how teams instrument, collect, and analyze telemetry.
Observability applies to a single application as well as a distributed system. In microservices, containers, and cloud environments, context becomes especially valuable because a user request may cross many components and some of those components may be short-lived.
Collecting large amounts of data does not guarantee observability. The data must be relevant, accessible, and sufficiently connected to answer operational questions.
How does observability differ from monitoring?
Monitoring tracks chosen health indicators and alerts on conditions that need attention. Observability supports deeper investigation into how the system behaves and why an issue may be occurring. The practices work together.
| Aspect | Monitoring | Observability |
| Purpose | Track selected health indicators and detect conditions that need attention. | Understand system behavior and investigate both expected and unexpected problems. |
| Typical question | Is checkout latency above the alert threshold? | Which requests are slow, where is the time spent, and what changed? |
| Typical outputs | Dashboards, health checks, alerts, and service level indicators. | Correlated telemetry, request context, and evidence for testing explanations. |
| Relationship | Monitoring provides signals that can start an investigation. | Observability includes the ability to monitor and then investigate with relevant context. |
For example, a checkout latency alert identifies a symptom. Investigating the affected requests, slow spans, related logs, and recent deployments helps engineers test possible explanations. Monitoring can cover many components; the distinction is about the questions and context supported, rather than the number of systems monitored.
What are the three pillars of observability?
Metrics, logs, and traces are commonly called the three pillars of observability. Each captures a different view of system behavior, and each has limitations.
| Signal | What it reveals | Example | Main limitation |
| Metrics | Numerical measurements and aggregates describing behavior over time. | Request rate, error rate, CPU usage, or a distribution of request durations. | Aggregates may hide individual events and cannot explain every failure on their own. |
| Logs | Timestamped event records with messages and attributes. | A payment timeout with a service name and trace ID. | Unstructured messages and missing identifiers make correlation difficult; volume can be costly. |
| Traces | The path and timing of a request or operation, represented by related spans. | A checkout request spanning the frontend, checkout service, and payment service. | Sampling and incomplete instrumentation can leave requests or operations unrepresented. |
What do metrics tell you?
Metrics describe numerical behavior such as request counts, memory usage, or operation durations. Counters track accumulated events, gauges represent values such as queue depth, and histograms summarize distributions such as request latency.
Measurements may occur as requests or other events happen, then be aggregated, scraped, or exported according to the collection setup. Metrics do not universally require each underlying measurement to occur at a fixed interval.
What do logs tell you?
Logs record events and their context. Structured fields such as timestamp, service, severity, operation, and trace ID can make a timeout or error easier to find and associate with a request. A useful log explains what happened without exposing secrets or unnecessary personal information.
What do traces tell you?
A trace represents a request or operation through related spans. A span describes an individual operation, including its start time, duration, and attributes. Parent-child relationships connect operations across service boundaries. Traces can help locate where time was spent, while additional evidence is often needed to explain the cause.
How do metrics, logs, and traces work together?
Correlate signals using consistent service and environment attributes, aligned timestamps, and request context. Logs emitted during a traced operation can carry the trace ID and span ID. Metrics can be compared by service, route, environment, and time window; supported exemplars can link an aggregate measurement to a particular trace.
Context propagation passes relevant context across process and service boundaries. Without it, operations from one request may appear as disconnected traces. Propagation must also cover asynchronous boundaries, where supported by the instrumentation.
Use trace IDs in logs and traces for request investigation. Avoid treating every unique request ID as a metric label, because that can create a separate time series for each request.
Deployment events, configuration changes, and infrastructure metadata provide further context. The goal is to assemble enough evidence to investigate behavior, not to collect a fixed checklist of signals without a clear purpose.
How does observability work in practice?
An observability workflow connects instrumentation with a usable investigation process:
- Generate telemetry - Instrument application code, libraries, infrastructure, and important dependencies.
- Collect and process it - Route telemetry through collectors or agents where appropriate. Apply processing such as batching and sensitive-data filtering.
- Store it in suitable backends - Select storage according to the signals, query needs, retention, and deployment requirements. Metrics, logs, and traces may use different backends.
- Query and correlate it - Use dashboards, search, trace views, and common attributes to inspect symptoms and relevant context.
- Respond and verify - Test an explanation, take an appropriate action, and check whether the user-facing problem has improved.
OpenTelemetry provides vendor-neutral instrumentation and telemetry transport components. Its Collector can receive, process, and export data; storage and visualization are supplied by other tools.
Example use case - investigating a slow checkout
Consider an illustrative checkout incident. The numbers and log record below are invented to explain the workflow.
- Identify the symptom - A dashboard shows checkout p95 latency rising from 250 milliseconds to 2 seconds. The p95 value indicates that 95% of measured request durations fall at or below that value for the selected population and time window.
- Narrow the scope - Compare services, environments, routes, and deployment versions to determine which requests are affected.
- Inspect a slow trace - A checkout request takes 1.9 seconds, with 1.7 seconds spent in a payment-service operation. This localizes the delay; it does not yet establish why the operation is slow.
- Find related logs - Search by the trace ID to inspect timeout messages, retries, and dependency errors for that request.
- Check what changed - Compare the incident start with deployments, configuration changes, and dependency behavior. Test whether the change explains the observations.
- Verify the response - After an appropriate fix or rollback, check latency and error rates across the affected population and inspect representative requests.
A simplified structured log record might look like this:
"timestamp": "2026-10-01T14:05:00Z",
"severity": "ERROR",
"service.name": "payment-service",
"trace_id": "11111111111111111111111111111111",
"span_id": "2222222222222222",
"message": "Payment gateway request timed out",
"duration_ms": 1700
This record supplies event details that an aggregate latency metric cannot provide. The trace shows the affected operation, and the shared ID connects the log with that request. A complete investigation considers both individual requests and the broader pattern.
How do you implement observability?
Start with a critical user journey and expand coverage according to the questions your team needs to answer.
- Choose a journey and an owner - Identify a flow such as checkout, account sign-in, or data ingestion. Map its services and dependencies and assign responsibility for investigation.
- Define service level indicators and objectives - A service level indicator (SLI) measures behavior such as successful requests or latency. A service level objective (SLO) sets a target over a defined window. Specify which events count and which are excluded.
- Instrument useful boundaries - Collect request rate, errors, duration, and relevant resource indicators. Add spans for important operations and structured logs for meaningful events. Check automatic instrumentation coverage before adding custom instrumentation.
- Standardize context - Use consistent service names, environment and version attributes, units, and timestamps. Propagate trace context and verify that related logs retain it.
- Configure the telemetry pipeline - Choose collectors, exporters, and compatible backends. Define sampling, retention, access controls, and filtering according to investigation needs and cost.
- Build actionable views and alerts - Show user-facing indicators alongside the resources and dependencies that explain them. Give each alert an owner and a practical investigation path.
- Validate with a controlled test - Introduce a known failure in a suitable test environment. Confirm that the alert, trace, logs, and deployment context support diagnosis.
- Maintain coverage - Revisit instrumentation as services change. Monitor the collection pipeline for dropped data, exporter errors, and gaps.
For example, an availability SLO might target 99.9% successful eligible requests over a rolling 30-day period. That is an illustrative target, not a universal recommendation. The remaining 0.1% is the error budget for that definition. Choose objectives according to user expectations and operational needs.
What are the benefits and use cases of observability?
Observability helps teams connect operational symptoms with evidence about system behavior. Its value depends on whether that evidence supports useful decisions.
- Debugging and incident response - connect errors with the requests, services, and dependencies involved, then verify whether a response addresses the problem.
- Performance optimization - inspect slow operations and resource usage to identify where an improvement may have the most effect.
- Deployment feedback - compare latency, failures, and service indicators before and after a release. Use defined evaluation criteria when telemetry informs deployment decisions.
- Capacity planning - examine demand, utilization, and saturation trends to inform resource planning. Account for changing workload assumptions when making projections.
- Cost management - compare resource consumption with workload and service behavior to identify possible inefficiencies. Include telemetry ingestion, storage, and query costs in the analysis.
- Business impact - combine operational indicators with explicitly collected product analytics, such as checkout completion, to assess how a change affects users.
- Security investigation - use relevant events and context to investigate suspicious behavior. Security detection still needs suitable signals, rules, and response workflows; general application instrumentation alone does not establish vulnerability coverage.
These practices give development and operations teams a shared view of how releases behave. They can support DevOps feedback loops, cross-team investigations, and decisions about reliability work.
Which tools support observability?
Observability tools perform different jobs in a telemetry workflow. Instrumentation, collection, storage, querying, visualization, and alerting may be provided by several products working together.
| Tool | Primary role | Where it fits |
| OpenTelemetry | Instrumentation and telemetry collection/export. | APIs, SDKs, instrumentation libraries, and a Collector help generate and route telemetry to selected backends. |
| Prometheus | Metrics monitoring and alerting. | Collects numerical time series, supports PromQL, and evaluates alerting rules; Alertmanager handles alert notifications. |
| Grafana | Visualization, exploration, and alerting. | Connects supported data sources so teams can query and explore metrics, logs, and traces. |
| Kibana | Exploration and visualization in the Elastic ecosystem. | Provides interfaces for exploring Elasticsearch data and building visualizations and dashboards. |
| Jaeger | Distributed tracing. | Supports collecting, storing, querying, and visualizing traces to investigate requests and service dependencies. |
| InfluxDB 3 | Time series storage and analysis. | Stores timestamped measurements and supports SQL queries and aggregations for telemetry analysis. |
These tools are examples of complementary roles, rather than equivalent replacements. A metrics database does not automatically supply trace exploration, and a visualization interface needs compatible data sources.
How does InfluxDB fit into an observability workflow?
InfluxDB 3 can store timestamped measurements and use SQL to filter, group, and aggregate telemetry. For example, engineers can compare error counts or resource utilization by service and time interval.
Choose ingestion, visualization, and other signal backends according to the application’s requirements. Verify the documented integration path for each signal and product version. The InfluxDB 3 SQL query guide provides examples for preparing data for analysis.
How do you manage observability cost and data quality?
Collect the context required to answer operational questions while making deliberate choices about volume, detail, and retention.
Control metric cardinality
Metric cardinality describes how many distinct time series the labels or attributes create. In Prometheus, each unique label combination creates a separate series. A user ID, request ID, or full URL containing unique values can cause rapid growth.
Prefer dimensions that serve a defined analysis, such as service, environment, or a templated route. Keep per-request identifiers in logs and traces where they are useful for investigation.
Choose sampling and retention deliberately
Trace sampling can reduce the number of traces retained, but it also determines which investigations the available data can support. Configure a strategy that suits the workload and verify whether important failures and slow requests remain represented.
Retention should reflect how far back engineers need to investigate and what detail they need. Aggregate metrics can support longer comparisons, while detailed events may have different retention needs. Document those choices so engineers understand the available evidence.
Filter sensitive data and measure overhead
Avoid recording secrets or unnecessary personal information. Inspect fields such as headers, request bodies, URLs, and log messages before exporting them. Apply appropriate collection controls, filtering, and access restrictions.
Measure instrumentation and exporter overhead under a representative workload. Monitor queue sizes, export failures, and dropped telemetry so gaps in the observability pipeline do not become invisible.
Check whether the telemetry answers real questions
A useful validation exercise asks an engineer to investigate a known issue using the available data. Check whether they can identify the affected service, connect a request with its logs, inspect dependencies, and compare behavior with a deployment or configuration change.
Use findings from incidents to improve instrumentation and investigation paths. More dashboards are useful when they answer a clear question and connect engineers with the underlying evidence.
