‹ Plugins / Basic Transformation
Scheduled Data-write
The Basic Transformation plugin cleans and standardizes raw time series data on ingest, so teams can normalize names, values, and formats without extra pipelines. It’s ideal for messy telemetry from sensors, apps, and infrastructure, making data easier to query, alert on, and act on. The result is analysis ready data faster, with less manual work and less operational overhead.
Configuration
Plugin parameters may be specified as key-value pairs in the --trigger-arguments flag (CLI) or in the trigger_arguments field (API) when creating a trigger. Some plugins support TOML configuration files, which can be specified using the plugin’s config_file_path parameter.
If a plugin supports multiple trigger specifications, some parameters may depend on the trigger specification that you use.
Plugin metadata
This plugin includes a JSON metadata schema in its docstring that defines supported trigger types and configuration parameters. This metadata enables the InfluxDB 3 Explorer UI to display and configure the plugin.
Required parameters
Parameter Type Default Description
measurement string required Source measurement containing data to transform
target_measurement string required Destination measurement for transformed data
target_database string current database Database for storing transformed data
dry_run string “false” When “true”, logs transformations without writing
Transformation parameters
names_transformations string none Field/tag name transformation rules. Format: ‘field1:”transform1 transform2”.field2:”transform3”’
values_transformations string none Field value transformation rules. Format: ‘field1:”transform1”.field2:”transform2”’
custom_replacements string none Custom string replacements. Format: ‘rule_name:”find=replace”’
custom_regex string none Regex patterns for field matching. Format: ‘pattern_name:”temp%”’
Data selection parameters
window string required (scheduled only) Historical data window. Format: (e.g., "30d", "1h")
included_fields string all fields and tags Dot-separated list of fields and tags to include (e.g., “temp.humidity.location”)
excluded_fields string none Dot-separated list of fields and tags to exclude
filters string none Query filters. Format: ‘field:”operator value”’
TOML configuration
config_file_path string none TOML config file path relative to PLUGIN_DIR (required for TOML configuration)
To use a TOML configuration file, set the PLUGIN_DIR environment variable and specify the config_file_path in the trigger arguments. This is in addition to the --plugin-dir flag when starting InfluxDB 3.
Example TOML configurations
For more information on using TOML configuration files, see the Using TOML Configuration Files section in the influxdb3_plugins/README.md.
Examples
Example 1: Temperature unit conversion
Convert temperature readings from Celsius to Fahrenheit while standardizing field names:
# Create the trigger
influxdb3 create trigger \
  --database weather \
  --path "gh:influxdata/basic_transformation/basic_transformation.py" \
  --trigger-spec "every:30m" \
  --trigger-arguments 'measurement=raw_temps,window=1h,target_measurement=temps_fahrenheit,names_transformations=Temperature:"snake",values_transformations=temperature:"convert_degC_to_degF"' \
  temp_converter
# Write test data
influxdb3 write \
  "raw_temps,location=office Temperature=22.5"
# Query transformed data (after trigger runs)
influxdb3 query \
  "SELECT * FROM temps_fahrenheit"
Expected output
location temperature time
office 72.5 2024-01-01T00:00:00Z
Transformation details:
  • Before: Temperature=22.5 (Celsius)
  • After: temperature=72.5 (Fahrenheit, field name converted to snake_case)
Example 2: Field name standardization
Clean and standardize field names from various sensors:
# Create trigger with multiple transformations
  --database sensors \
  --trigger-spec "all_tables" \
  --trigger-arguments 'measurement=raw_sensors,target_measurement=clean_sensors,names_transformations=.*:"remove_special_chars snake collapse_underscore trim_underscore"' \
  field_cleaner
# Write data with inconsistent field names
influxdb3 write \
  "raw_sensors,device=sensor1 \"Room Temperature\"=20.1,\"__Humidity_%\"=45.2"
# Query cleaned data
influxdb3 query \
  "SELECT * FROM clean_sensors"
Expected output
device room_temperature humidity time
sensor1 20.1 45.2 2024-01-01T00:00:00Z
  • Before: "Room Temperature"=20.1, "__Humidity_%"=45.2
  • After: room_temperature=20.1, humidity=45.2 (field names standardized)
Example 3: Custom string replacements
Replace specific strings in field values:
# Create trigger with custom replacements
  --database inventory \
  --trigger-spec "every:1d" \
  --trigger-arguments 'measurement=products,window=7d,target_measurement=products_updated,values_transformations=status:"status_replace",custom_replacements=status_replace:"In Stock=available.Out of Stock=unavailable"' \
  status_updater
Ready to get started?
Download InfluxDB 3 and have Basic Transformation running in minutes.
