State Change
The State Change plugin detects meaningful changes and threshold breaches in time series data, then triggers alerts when they matter. It’s ideal for infrastructure, app health, and sensor monitoring, helping teams catch issues earlier, cut alert noise, and simplify monitoring inside InfluxDB.
Configuration
Plugin parameters may be specified as key-value pairs in the --trigger-arguments flag (CLI) or in the trigger_arguments field (API) when creating a trigger. Some plugins support TOML configuration files, which can be specified using the plugin’s config_file_path parameter.
If a plugin supports multiple trigger specifications, some parameters may depend on the trigger specification that you use.
Plugin metadata
This plugin includes a JSON metadata schema in its docstring that defines supported trigger types and configuration parameters. This metadata enables the InfluxDB 3 Explorer UI to display and configure the plugin.
Required parameters
| Parameter | Type | Default | Description |
measurement |
string | required | Measurement to monitor for field changes |
field_change_count |
string | required | Dot-separated field thresholds (for example, “temp:3.load:2”). Supports count-based conditions |
senders |
string | required | Dot-separated notification channels with multi-channel alert support (Slack, Discord, etc.) |
window |
string | required | Time window for analysis. Format: <number><unit> (for example, “10m”, “1h”) |
Data write trigger parameters
measurement |
string | required | Measurement to monitor for threshold conditions |
field_thresholds |
string | required | Flexible threshold conditions with count-based and duration-based support (e.g., “temp:30:10@status:ok:1h”) |
senders |
string | required | Dot-separated notification channels with multi-channel alert support (Slack, Discord, HTTP, SMS, WhatsApp) |
Notification parameters
influxdb3_auth_token |
string | env var | InfluxDB 3 API token with environment variable support for credential management |
notification_text |
string | template | Customizable message template for scheduled notifications with dynamic variables |
notification_count_text |
string | template | Customizable message template for count-based notifications with dynamic variables |
notification_time_text |
string | template | Customizable message template for time-based notifications with dynamic variables |
notification_path |
string | “notify” | Notification endpoint path |
port_override |
number | 8181 | InfluxDB port override |
Advanced parameters
state_change_window |
number | 1 | Recent values to check for stability (configurable state change detection to reduce noise) |
state_change_count |
number | 1 | Max changes allowed within stability window (configurable state change detection) |
TOML configuration
config_file_path |
string | none | TOML config file path relative to PLUGIN_DIR (required for TOML configuration) |
To use a TOML configuration file, set the PLUGIN_DIR environment variable and specify the config_file_path in the trigger arguments. This is in addition to the --plugin-dir flag when starting InfluxDB 3.
Example TOML configuration files provided:
- state_change_config_scheduler.toml - for scheduled triggers
- state_change_config_data_writes.toml - for data write triggers
For more information on using TOML configuration files, see the Using TOML Configuration Files section in the influxdb3_plugins/README.md.
Channel-specific configuration
Notification channels require additional parameters based on the sender type (same as the influxdata/notifier plugin).
Examples
Example 1: Scheduled field change monitoring
Monitor field changes over a time window and alert when thresholds are exceeded:
# Write test data with changing values (7 writes = 6 changes)
influxdb3 write \
--database sensors \
"temperature,location=office value=22.5"
influxdb3 write \
"temperature,location=office value=25.0"
influxdb3 write \
"temperature,location=office value=22.8"
influxdb3 write \
"temperature,location=office value=26.5"
influxdb3 write \
"temperature,location=office value=23.0"
influxdb3 write \
"temperature,location=office value=27.2"
influxdb3 write \
"temperature,location=office value=24.0"
# Create and enable the trigger
influxdb3 create trigger \
--path "gh:influxdata/state_change/state_change_check_plugin.py" \
--trigger-spec "every:15m" \
--trigger-arguments "measurement=temperature,field_change_count=value:5,window=1h,senders=slack,slack_webhook_url=$SLACK_WEBHOOK_URL" \
temp_change_monitor
influxdb3 enable trigger --database sensors temp_change_monitor
Set SLACK_WEBHOOK_URL to your Slack incoming webhook URL.
Expected output
When the field changes more than 5 times within 1 hour, a notification is sent: “Temperature sensor value changed 6 times in 1h for tags location=office”
Example 2: Advanced scheduled field change monitoring
--trigger-arguments "measurement=temperature,field_change_count=value:5,window=1h,senders=slack,slack_webhook_url=$SLACK_WEBHOOK_URL,notification_text=Temperature sensor $field changed $changes times in $window for tags $tags" \
temp_change_monitor
Real-time threshold detection
Monitor data writes for threshold conditions:
--database monitoring \
--trigger-spec "all_tables" \
--trigger-arguments "measurement=system_metrics,field_thresholds=cpu_usage:80:5@memory_usage:90:10min,senders=discord,discord_webhook_url=$DISCORD_WEBHOOK_URL" \
system_threshold_monitor
Set DISCORD_WEBHOOK_URL to your Discord incoming webhook URL.
Multi-condition monitoring
Monitor multiple fields with different threshold types:
--database application \
--trigger-arguments "measurement=app_health,field_thresholds=error_rate:0.05:3@response_time:500:30s@status:down:1,senders=slack.sms,slack_webhook_url=$SLACK_WEBHOOK_URL,twilio_from_number=+1234567890,twilio_to_number=+0987654321" \
app_health_monitor
Ready to get started?
Download InfluxDB 3 and have running in minutes.
