‹ Plugins / Anomaly Detection ADTK
Scheduled
The Anomaly Detection ADTK Plugin provides machine learning-based anomaly detection for time series data in InfluxDB 3 using the ADTK (Anomaly Detection Toolkit) library. Detect outliers using algorithms like Isolation Forest, Local Outlier Factor, and One-Class SVM, and write detection results to a separate output table for analysis and alerting.
Configuration
Plugin parameters may be specified as key-value pairs in the --trigger-arguments flag (CLI) or in the trigger_arguments field (API) when creating a trigger.
Plugin metadata
This plugin includes a JSON metadata schema in its docstring that defines supported trigger types and configuration parameters. This metadata enables the InfluxDB 3 Explorer UI to display and configure the plugin.
Required parameters
Parameter Type Default Description
database string required Target database name for anomaly detection results
table string required Source table name containing time series data
field string required Numeric field name to analyze for anomalies
output_table string required Destination table name for anomaly detection results
Optional parameters
detector_type string IsolationForestAD Anomaly detection algorithm (IsolationForestAD, LocalOutlierFactorAD, OneClassSVMAD)
contamination float 0.1 Expected proportion of anomalies in the dataset (0.0 to 0.5)
window_size integer 10 Number of data points to include in detection window
time_column string time Column name containing timestamp values
Examples
Example 1: Basic anomaly detection with Isolation Forest
Write test data and detect anomalies:
# Write normal sensor data
influxdb3 write \
  --database mydb \
  "sensor_data,location=factory temperature=22.5"
influxdb3 write \
  --database mydb \
  "sensor_data,location=factory temperature=23.1"
influxdb3 write \
  --database mydb \
  "sensor_data,location=factory temperature=85.0"  # Anomaly
# Create and enable the trigger
influxdb3 create trigger \
  --database mydb \
  --path "gh:influxdata/anomaly_detection_adtk/anomaly_detection_adtk.py" \
  --trigger-spec "every:5m" \
  --trigger-arguments "database=mydb,table=sensor_data,field=temperature,output_table=temperature_anomalies" \
  temp_anomaly_detector
influxdb3 enable trigger --database mydb temp_anomaly_detector
# Query anomaly detection results (after trigger runs)
influxdb3 query \
  --database mydb \
  "SELECT * FROM temperature_anomalies ORDER BY time DESC LIMIT 5"
Expected output
| time                 | temperature | score | is_anomaly|
| 2025-06-01T10:02:00Z | 85.0        | -0.95 | true     |
| 2025-06-01T10:01:00Z | 23.1        | 0.12  | false    |
| 2025-06-01T10:00:00Z | 22.5        | 0.08  | false    |
Example 2: Local Outlier Factor detection
Use Local Outlier Factor for density-based anomaly detection:
  --database monitoring \
  --trigger-spec "every:10m" \
  --trigger-arguments "database=monitoring,table=cpu_metrics,field=usage,output_table=cpu_anomalies,detector_type=LocalOutlierFactorAD,contamination=0.05,window_size=30" \
  cpu_lof_detector
Example 3: One-Class SVM detection
Use One-Class SVM for novelty detection:
  --database production \
  --trigger-spec "every:15m" \
  --trigger-arguments "database=production,table=network_traffic,field=bytes_in,output_table=traffic_anomalies,detector_type=OneClassSVMAD,contamination=0.02,window_size=50" \
  network_svm_detector
Ready to get started?
Download InfluxDB 3 and have Anomaly Detection ADTK running in minutes.
