‹ Plugins / Kafka Subscriber
Scheduled
Kafka Subscriber
The Kafka Subscriber Plugin enables real-time ingestion of Kafka messages into InfluxDB 3. Subscribe to Kafka topics and automatically transform messages into time-series data with support for JSON, Line Protocol, and custom text formats. The plugin uses consumer groups for reliable message delivery and provides flexible offset commit policies for different use cases.
Important: Protobuf and Avro formats are NOT supported as they require Schema Registry integration. For these formats, consider using an external deserialization layer before writing to Kafka in a supported format.
Software Requirements
  • InfluxDB 3 Core/Enterprise: with the Processing Engine enabled
  • Python packages:
    • confluent-kafka (High-performance Kafka client library based on librdkafka)
    • jsonpath-ng (JSON path parsing for JSON format)
Installation steps
  1. Start InfluxDB 3 with the Processing Engine enabled (--plugin-dir /path/to/plugins):
    influxdb3 serve \
      --node-id node0 \
      --object-store file \
      --data-dir ~/.influxdb3 \
      --plugin-dir ~/.plugins
  2. Install required Python packages:
    influxdb3 install package confluent-kafka
    influxdb3 install package jsonpath-ng
Configuration
Plugin parameters may be specified as key-value pairs in the --trigger-arguments flag (CLI) or in the trigger_arguments field (API) when creating a trigger. This plugin supports TOML configuration files for complex mapping scenarios, which can be specified using the config_file_path parameter.
Plugin metadata
This plugin includes a JSON metadata schema in its docstring that defines supported trigger types and configuration parameters. This metadata enables the InfluxDB 3 Explorer UI to display and configure the plugin.
Required parameters
In TOML configuration, bootstrap_servers, topics, and group_id are placed under the [kafka] section; table_name and table_name_field are placed under [mapping.json] or [mapping.text] section.
Parameter Type Default Description
bootstrap_servers string required Space-separated list of Kafka broker addresses (e.g., “kafka1:9092 kafka2:9092”)
topics string required Space-separated list of topics (e.g., “sensor_data metrics”)
group_id string required Kafka consumer group ID (must be unique per consumer group)
table_name string required (json/text only) InfluxDB measurement name for storing data. Not required for lineprotocol format or when table_name_field is set.
table_name_field string none JSON field name or regex pattern to extract table name dynamically from each message. Alternative to static table_name.
Connection parameters
In TOML configuration, these parameters are placed under the [kafka] section.
auto_offset_reset string “earliest” Where to start consuming on first connect: “earliest” or “latest”
max_poll_records int 500 Maximum messages per scheduled call. Set to 0 for unlimited.
Offset Commit Policy
In TOML configuration, this parameter is placed under the [kafka] section.
offset_commit_policy string “on_success” When to commit offsets: “on_success” or “always”
Policy behavior:
Policy Behavior
on_success Commit offsets only after ALL messages in the batch are successfully processed and written
always Commit offsets immediately after receiving messages, regardless of processing success
When to use each policy:
  • on_success (recommended): Use when data integrity is important. Failed messages will be reprocessed on the next trigger execution.
  • always: Use in high-throughput scenarios where occasional data loss is acceptable, or when you have external error handling (failed messages are logged to kafka_exceptions table).
Security parameters
security_protocol string “PLAINTEXT” Security protocol: “PLAINTEXT”, “SSL”, “SASL_PLAINTEXT”, “SASL_SSL”
SASL Authentication parameters
In TOML configuration, these parameters are placed under the [kafka.sasl] section with shortened names.
Parameter (CLI) Parameter (TOML) Type Default Description
sasl_mechanism [kafka.sasl] mechanism string none SASL mechanism: “PLAIN”, “SCRAM-SHA-256”, “SCRAM-SHA-512”
sasl_username [kafka.sasl] username string none SASL username (required with sasl_mechanism)
sasl_password [kafka.sasl] password string none SASL password (required with sasl_mechanism)
Note: All three SASL parameters must be provided together when using SASL authentication.
SSL/TLS parameters
In TOML configuration, these parameters are placed under the [kafka.ssl] section with shortened names.
ssl_ca_cert [kafka.ssl] ca_cert string none Path to CA certificate file
ssl_cert [kafka.ssl] client_cert string none Path to client certificate for mutual TLS
ssl_key [kafka.ssl] client_key string none Path to client private key for mutual TLS
ssl_key_password [kafka.ssl] key_password string none Password for encrypted client private key
Note: For mutual TLS, both ssl_cert and ssl_key must be provided together.
Message format parameters
In TOML configuration, format is placed under the [kafka] section; timestamp_field is placed under [mapping.json] or [mapping.text] section.
format string “json” Message format: json, lineprotocol, or text
timestamp_field string none Field containing timestamp (format depends on message format)
Supported formats:
Format Description
json JSON with JSONPath field mapping
lineprotocol InfluxDB Line Protocol passthrough
text Plain text with regex-based parsing
Format-specific timestamp_field syntax:
Format Syntax Split Method Example (CLI) Example (TOML)
JSON field_name:format Split by first : "timestamp:ms" "$.timestamp:ms"
Text regex:format Split by last : "ts:(\\d+):ms" "ts:(\\d+):ms"
Supported timestamp formats: - ns - nanoseconds (Unix timestamp) - ms - milliseconds (Unix timestamp) - s - seconds (Unix timestamp) - datetime - ISO 8601 string (e.g., “2021-12-01T12:00:00Z”)
JSON format parameters
In TOML configuration, tags are placed under [mapping.json.tags] section and fields under [mapping.json.fields] section.
tags string none Space-separated tag names. Example: “room sensor location”
fields string required Space-separated field mappings. Format: “name:type=jsonpath” without $.
Field specification format: "temp:float=temperature hum:int=humidity status:bool=online"
Supported field types: int, uint, float, string, bool
Text format parameters
In TOML configuration, tags are placed under [mapping.text.tags] section and fields under [mapping.text.fields] section.
tags string none Space-separated tag patterns. Format: “name=regex_pattern”
fields string required Space-separated field patterns. Format: “name:type=regex_pattern”
TOML configuration
config_file_path string none Path to TOML config file (absolute or relative)
File path resolution
All file paths in the plugin (configuration file, TLS certificates) follow the same resolution logic:
  • Absolute paths (e.g., /etc/kafka/config.toml) are used as-is
  • Relative paths (e.g., config.toml, certs/ca.crt) are resolved from PLUGIN_DIR environment variable
If a relative path is specified and PLUGIN_DIR is not set, the plugin will return an error.
Example TOML configuration
kafka_config_example.toml - comprehensive configuration example with all formats and security options
Quick Start
Scheduled ingestion with TOML configuration
Recommended for production use with complex mappings:
# 1. Set PLUGIN_DIR environment variable
export PLUGIN_DIR=~/.plugins
# 2. Copy and edit configuration file
cp kafka_config_example.toml $PLUGIN_DIR/my_kafka_config.toml
# Edit my_kafka_config.toml with your Kafka cluster and mapping settings
# 3. Create the trigger
influxdb3 create trigger \
  --database mydb \
  --plugin-filename gh:influxdata/kafka_subscriber/kafka_subscriber.py \
  --trigger-spec "every:10s" \
  --trigger-arguments config_file_path=my_kafka_config.toml \
  kafka_ingestion
Scheduled ingestion with command-line arguments
For simple JSON message ingestion:
  --database mydb \
  --trigger-spec "every:5s" \
  --trigger-arguments 'bootstrap_servers=kafka1:9092 kafka2:9092,topics=sensors.temperature sensors.humidity,group_id=influxdb3_consumer,format=json,table_name=sensor_data,fields=temp:float=temperature hum:int=humidity,tags=location sensor_id' \
  kafka_sensors
Secure Kafka connection with SASL_SSL
  --database mydb \
  --trigger-arguments 'bootstrap_servers=kafka1:9093 kafka2:9093,topics=secure.data,group_id=influxdb3_secure,format=json,table_name=secure_data,security_protocol=SASL_SSL,sasl_mechanism=SCRAM-SHA-512,sasl_username=myuser,sasl_password=mypass,ssl_ca_cert=certs/ca.crt,fields=value:float=value' \
  secure_kafka
Troubleshooting
Check Plugin Logs
influxdb3 query --database _internal \
  "SELECT * FROM system.processing_engine_logs
   WHERE trigger_name = 'kafka_ingestion'
   ORDER BY time DESC LIMIT 20"
Common Issues
“confluent-kafka library not installed” or “No module named ‘confluent_kafka’”
If you encounter librdkafka related errors: - Ubuntu/Debian: sudo apt-get install librdkafka-dev - macOS: brew install librdkafka
“Configuration file not found”
  • For relative paths, ensure PLUGIN_DIR environment variable is set
  • For absolute paths, verify the file exists at the specified location
# For relative paths
ls $PLUGIN_DIR/my_kafka_config.toml
# Or use absolute path
ls /etc/kafka/my_kafka_config.toml
“Failed to connect to Kafka cluster”
  • Verify bootstrap_servers addresses and ports
  • Check network connectivity to Kafka brokers
  • For SSL connections, verify certificate paths
  • For SASL authentication, verify credentials
“SASL mechanism required when security_protocol includes SASL”
When using SASL_PLAINTEXT or SASL_SSL, you must provide: - sasl_mechanism - sasl_username - sasl_password
“No fields were mapped from JSON data”
  • Verify JSONPath expressions in field mappings (use $. prefix)
  • Check that JSON structure matches your paths
  • Review kafka_exceptions table for detailed errors
Messages not being processed
  • Check trigger status: influxdb3 show summary --database mydb
  • Verify Kafka connection in plugin logs
  • Check consumer group lag using Kafka tools
  • Increase trigger frequency (e.g., from every:10s to every:5s)
  • If many messages are queued, increase max_poll_records or set to 0 (unlimited)
Offset commit issues with on_success policy
If using offset_commit_policy=on_success and seeing repeated message processing: - Check kafka_exceptions table for processing errors - Fix the root cause of failures - Consider using offset_commit_policy=always if some data loss is acceptable
Data requirements
The plugin automatically creates the target measurement table on first write. Field mappings are required for JSON and Text formats to specify which fields to extract and their data types.
Message encoding requirements
  • UTF-8 text only: The plugin only processes UTF-8 encoded text messages. Binary messages (Protobuf, Avro) are not supported.
  • Non-empty payloads: Empty or whitespace-only messages are automatically skipped.
Message Formats
JSON Format
The primary use case for structured data. Supports nested fields using JSONPath expressions.
TOML Configuration
[kafka]
bootstrap_servers = ["kafka:9092"]
topics = ["sensors.temperature"]
group_id = "influxdb3_json"
format = "json"
[mapping.json]
table_name = "sensor_data"
timestamp_field = "$.timestamp:ms"
[mapping.json.tags]
location = "$.location"
sensor_id = "$.sensor.id"
temperature = ["$.temp", "float"]
humidity = ["$.humidity", "int"]
status = ["$.online", "bool"]
Example Message
  "timestamp": 1638360000000,
  "location": "warehouse_a",
  "sensor": {
    "id": "sensor_001"
  "temp": 22.5,
  "humidity": 65,
  "online": true
Resulting Data
sensor_data,location=warehouse_a,sensor_id=sensor_001 temperature=22.5,humidity=65i,status=true 1638360000000000000
JSON Array Support
Process batch messages containing arrays of JSON objects:
  {"timestamp": 1638360000000, "sensor_id": "001", "temperature": 22.5},
  {"timestamp": 1638360001000, "sensor_id": "002", "temperature": 23.1},
  {"timestamp": 1638360002000, "sensor_id": "003", "temperature": 21.8}
Array processing behavior: - Each array element is processed independently as a separate data point - If one element fails to parse, the others continue processing (partial success) - Parse errors for individual elements are logged to kafka_exceptions table - Statistics count 1 Kafka message = 1 unit (regardless of array size)
Line Protocol Format
For messages already in InfluxDB line protocol format, use passthrough mode. No mapping configuration needed.
TOML Configuration
[kafka]
topics = ["influxdb.metrics"]
group_id = "influxdb3_lineprotocol"
format = "lineprotocol"
Example Message
sensor_data,location=warehouse_a,sensor_id=001 temperature=22.5,humidity=65i 1638360000000000000
Text Format
Parse plain text messages using regular expressions:
TOML Configuration
[kafka]
topics = ["legacy.logs"]
group_id = "influxdb3_text"
format = "text"
[mapping.text]
table_name = "sensor_logs"
timestamp_field = "ts:(\\d+):ms"
[mapping.text.tags]
location = "location=([^,\\s]+)"
temperature = ["temp:([\\d.]+)", "float"]
humidity = ["hum:(\\d+)", "int"]
Example Message
location=warehouse_a,temp:22.5,hum:65,ts:1638360000000
Statistics and Monitoring
The plugin tracks comprehensive statistics and writes them to the kafka_stats table every 10 plugin calls.
kafka_stats Table
Field Type Description
topic (tag) tag Kafka topic name
partition (tag) tag Partition number
consumer_group (tag) tag Consumer group ID
bootstrap_servers (tag) tag Kafka cluster address
messages_received int Total messages received
messages_processed int Successfully processed messages
messages_failed int Failed messages
last_offset int Last processed offset for this partition
success_rate float Percentage of successful messages
Querying Statistics
# Get latest statistics
influxdb3 query --database mydb \
  "SELECT * FROM kafka_stats ORDER BY time DESC LIMIT 10"
# Success rate by topic
  "SELECT topic, partition, success_rate, messages_processed, messages_failed
   FROM kafka_stats
   WHERE time > now() - INTERVAL '1 hour'
   ORDER BY time DESC"
# Check consumer lag indicators
  "SELECT topic, partition, last_offset
   FROM kafka_stats
   WHERE consumer_group = 'influxdb3_consumer'
Error Handling
Parse errors and message processing failures are logged to the kafka_exceptions table:
kafka_exceptions Table
topic (tag) tag Kafka topic where error occurred
error_type (tag) tag Type of error (e.g., JSONDecodeError)
offset int Message offset
error_message string Detailed error message
raw_message string Original message (truncated to 1KB)
Checking for Errors
  "SELECT * FROM kafka_exceptions ORDER BY time DESC LIMIT 10"
Architecture
How It Works
  1. Scheduled Trigger: Plugin runs on schedule (e.g., every:10s)
  2. Configuration Caching: Plugin configuration is parsed once and cached between executions
  3. Consumer Poll: Kafka consumer polls for available messages (drains all available messages)
  4. Offset Commit: Based on offset_commit_policy:
    • always: Commits immediately after poll
    • on_success: Commits only after successful processing of all messages
  5. Parse & Write: Messages parsed according to format and written to InfluxDB
  6. Error Tracking: Parse errors logged to kafka_exceptions table
  7. Statistics: Written to kafka_stats table every 10 plugin calls
Performance Optimization
The plugin includes several optimizations for high-throughput scenarios:
  • Configuration Caching: Plugin configuration is parsed once and reused across all trigger executions
  • Pre-compiled Patterns: JSONPath expressions and regex patterns are compiled once during parser initialization
  • Batch Polling: Consumer drains available messages in a single trigger execution (limited by max_poll_records, default 500)
  • Manual Offset Commit: Provides control over exactly-once vs at-least-once semantics
Consumer Group Behavior
  • Each trigger execution creates a new consumer connection
  • Consumer group ID ensures partitions are assigned consistently
  • Offsets are committed to Kafka for durability
  • Multiple plugin instances with the same group_id will share partitions (load balancing)
Ready to get started?
Download InfluxDB 3 and have Kafka Subscriber running in minutes.
