‹ Plugins / MQTT Subscriber
Scheduled
MQTT Subscriber
The MQTT Subscriber plugin brings MQTT data into InfluxDB 3 without custom subscribers or transforms. It simplifies ingestion for IoT, sensors, edge monitoring, and MQTT event streams, improving reliability and getting real-time data into InfluxDB faster with less engineering overhead.
Configuration
Plugin parameters may be specified as key-value pairs in the --trigger-arguments flag (CLI) or in the trigger_arguments field (API) when creating a trigger. This plugin supports TOML configuration files for complex mapping scenarios, which can be specified using the config_file_path parameter.
Plugin metadata
This plugin includes a JSON metadata schema in its docstring that defines supported trigger types and configuration parameters. This metadata enables the InfluxDB 3 Explorer UI to display and configure the plugin.
Required parameters
In TOML configuration, broker_host and topics are placed under the [mqtt] section; table_name and table_name_field are placed under [mapping.json] or [mapping.text] section.
Parameter Type Default Description
broker_host string required MQTT broker hostname or IP address
topics string required Space-separated list of topics (e.g., “sensors/temp sensors/humidity”)
table_name string required (json/text only) InfluxDB measurement name for storing data. Not required for lineprotocol format or when table_name_field is set.
table_name_field string none JSON field name or regex pattern to extract table name dynamically from each message. Alternative to static table_name.
Connection parameters
In TOML configuration, these parameters are placed under the [mqtt] section.
broker_port integer 1883 MQTT broker port (1883 for non-TLS, 8883 for TLS)
qos integer 1 MQTT Quality of Service level (0, 1, or 2)
client_id string auto-generated MQTT client identifier (must be unique per broker)
Recommendation: Use QoS 1 for most IoT scenarios. It provides reliable delivery with minimal overhead.
Authentication parameters
In TOML configuration, these parameters are placed under the [mqtt.auth] section.
username string none MQTT broker username (required with password)
password string none MQTT broker password (required with username)
Note: Both username and password must be provided together for authentication.
TLS/SSL parameters
In TOML configuration, these parameters are placed under the [mqtt.tls] section.
ca_cert string none Path to CA certificate file
client_cert string none Path to client certificate for mutual TLS
client_key string none Path to client private key for mutual TLS
Note: For mutual TLS, both client_cert and client_key must be provided together.
Message format parameters
In TOML configuration, format is placed under the [mqtt] section; timestamp_field is placed under [mapping.json] or [mapping.text] section.
format string “json” Message format: json, lineprotocol, or text
timestamp_field string none Field containing timestamp (format depends on message format)
Format-specific timestamp_field syntax:
The timestamp field format differs between JSON and Text formats:
Format Syntax Split Method Example (CLI) Example (TOML)
JSON field_name:format Split by first : "timestamp:ms" "$.timestamp:ms"
Text regex:format Split by last : "ts:(\\d+):ms" "ts:(\\d+):ms"
Note: In CLI arguments, JSON paths are specified without $. prefix (added automatically). In TOML configuration, use full JSONPath syntax with $. prefix.
Note: Text format uses the last colon to split, allowing regex patterns to contain colons (e.g., time patterns).
Supported timestamp formats: - ns - nanoseconds (Unix timestamp) - ms - milliseconds (Unix timestamp) - s - seconds (Unix timestamp) - datetime - ISO 8601 string (e.g., “2021-12-01T12:00:00Z”)
JSON format parameters
In TOML configuration, tags are placed under [mapping.json.tags] section and fields under [mapping.json.fields] section.
tags string none Space-separated tag names. Example: “room sensor location”
fields string required Space-separated field mappings. Format: “name:type=jsonpath” without $.
Field specification format: "temp:float=temperature hum:int=humidity status:bool=online"
Supported field types: int, uint, float, string, bool
Text format parameters
In TOML configuration, tags are placed under [mapping.text.tags] section and fields under [mapping.text.fields] section.
tags string none Space-separated tag patterns. Format: “name=regex_pattern”
fields string required Space-separated field patterns. Format: “name:type=regex_pattern”
Tag specification format: "room=room:([^,\\s]+) sensor=sensor:(\\w+)"
Field specification format: "temp:float=temp:([\\d.]+) status:bool=(true|false)"
TOML configuration
config_file_path string none Path to TOML config file (absolute or relative)
To use a TOML configuration file, specify the config_file_path in the trigger arguments.
File path resolution
All file paths in the plugin (configuration file, TLS certificates) follow the same resolution logic:
  • Absolute paths (e.g., /etc/mqtt/config.toml) are used as-is
  • Relative paths (e.g., config.toml, certs/ca.crt) are resolved from PLUGIN_DIR environment variable
If a relative path is specified and PLUGIN_DIR is not set, the plugin will return an error.
Example TOML configuration
mqtt_config_example.toml - comprehensive configuration example with all three message formats
Ready to get started?
Download InfluxDB 3 and have MQTT Subscriber running in minutes.
