‹ Plugins / Schema Validator
Data-write
Schema Validator
The Schema Validator plugin validates data against a defined schema before it lands in InfluxDB, preventing bad telemetry from polluting queries, alerts, and analytics. It’s ideal for IoT, multi source pipelines, and any workflow that depends on clean, analysis ready data.
Configuration
The schema is defined in a JSON file. Here is the full structure:
    "allowed_measurements": ["weather", "cpu"],
    "tables": {
        "weather": {
            "target_table": "weather_clean",
            "tags": {
                "location": {
                    "required": true,
                    "allowed_values": ["us-east", "us-west", "eu-west"]
                "station_id": {
                    "required": true
                "region": {
                    "required": false
            "fields": {
                "temperature": {
                    "required": true,
                    "type": "float"
                "humidity": {
                    "required": true,
                    "type": "float"
                "condition": {
                    "required": false,
                    "type": "string",
                    "allowed_values": ["sunny", "cloudy", "rain", "snow"]
Examples
IoT Sensor Validation
Ensure sensor readings always have a device_id, valid sensor type, and a numeric value:
    "allowed_measurements": ["sensor_readings"],
    "tables": {
        "sensor_readings": {
            "target_table": "sensors_validated",
            "tags": {
                "device_id": { "required": true },
                "sensor_type": {
                    "required": true,
                    "allowed_values": ["temperature", "pressure", "humidity"]
            "fields": {
                "value": { "required": true, "type": "float" },
                "status": {
                    "required": false,
                    "type": "string",
                    "allowed_values": ["ok", "warning", "critical"]
Multi-table with Cross-database
Validate weather and cpu data from raw_db, writing clean data to clean_db:
influxdb3 create trigger \
  --database raw_db \
  --plugin-filename schema_validator.py \
  --trigger-spec \"all_tables\" \
  --trigger-arguments schema_file=schema_validator_config.json,target_database=clean_db,write_rejection_log=true \
  schema_validator_all
Monitoring Rejections
Query the rejection log to see what data is being rejected and why:
SELECT * FROM _schema_rejections
WHERE time > now() - INTERVAL '1 hour'
ORDER BY time DESC
Ready to get started?
Download InfluxDB 3 and have Schema Validator running in minutes.
