InfluxDB vs Elasticsearch
A detailed comparison
Compare InfluxDB and Elasticsearch for time series and OLAP workloads
Updated June 16, 2026
Learn About Time Series DatabasesChoosing the right database is a critical choice when building any software application. All databases have different strengths and weaknesses when it comes to performance, so deciding which database has the most benefits and the most minor downsides for your specific use case and data model is an important decision. Below you will find an overview of the key concepts, architecture, features, use cases, and pricing models of InfluxDB and Elasticsearch so you can quickly see how they compare against each other.
The primary purpose of this article is to compare how InfluxDB and Elasticsearch perform for workloads involving time series data, not for all possible use cases. Time series data typically presents a unique challenge in terms of database performance. This is due to the high volume of data being written and the query patterns to access that data. This article doesn't intend to make the case for which database is better; it simply provides an overview of each database so you can make an informed decision.
InfluxDB vs Elasticsearch Breakdown
| Database Model | Distributed search and analytics engine, document-oriented |
| Architecture | Cloud-native architecture available as a fully managed cloud service or self-managed on your own hardware |
Elasticsearch is built on top of Apache Lucene and uses a RESTful API for communication. It stores data in a flexible JSON document format, and the data is automatically indexed for fast search and retrieval. Elasticsearch can be deployed as a single node, in a cluster configuration, or as a managed cloud service (Elastic Cloud) |
| License | InfluxDB 3 Core: MIT (open source). InfluxDB 3 Enterprise: commercial license. |
Elastic License |
| Use Cases | Monitoring, observability, IoT, real-time analytics, Industrial AI, Aerospace |
Full-text search, log and event data analysis, real-time application monitoring, analytics |
| Scalability | Horizontally scalable with decoupled compute and storage; object storage reduces infrastructure costs significantly |
Horizontally scalable with support for data sharding, replication, and distributed querying |
Looking for the most efficient way to get started?
Whether you are looking for cost savings, lower management overhead, or open source, InfluxDB can help.
InfluxDB Overview
InfluxDB is a time series database built for storing metrics, events, logs, and traces. InfluxData released the first version in 2013. It is the most widely deployed time series database in the world and consistently ranks #1 in the DB-Engines time series database category with a 21.60 score.
InfluxDB 3 is the most recent version of InfluxDB. Its architecture separates compute and storage, so each scales independently based on workload demands. InfluxDB 3 supports standard SQL and InfluxQL, a time-series-optimized query language with built-in functions for downsampling, windowed aggregations, and time-range filtering.
InfluxDB 3 is available in five deployment options:
- InfluxDB 3 Core: Open source, self-managed, MIT licensed.
- InfluxDB 3 Enterprise: Self-managed with enterprise capabilities including clustering, role-based access control, and automated backup and restore.
- InfluxDB Cloud Serverless: Fully managed, usage-based pricing, available across major cloud providers.
- InfluxDB Cloud Dedicated: Managed cloud on dedicated infrastructure for workloads requiring isolation or hardware-level configuration.
- Amazon Timestream for InfluxDB: InfluxDB fully managed by AWS, natively integrated
Elasticsearch Overview
Elasticsearch is an open-source distributed search and analytics engine built on top of Apache Lucene. It was first released in 2010 and has since become popular for its scalability, near real-time search capabilities, and ease of use. Elasticsearch is designed to handle a wide variety of data types, including structured, unstructured, and time-based data. It is often used in conjunction with other tools from the Elastic Stack, such as Logstash for data ingestion and Kibana for data visualization.
InfluxDB for Time Series Data
InfluxDB is the right choice when the workload is time series by nature: data arrives continuously, records are rarely modified after they are written, queries span time ranges, and volume grows with the number of sources rather than user activity.
InfluxDB is purpose-built for these workloads:
- Infrastructure and application observability: server metrics, container telemetry, Kubernetes monitoring
- Machine learning and AI: High-frequency feature data, model performance metrics, and inference telemetry at the latency and scale ML pipelines require
- IoT and industrial sensor data: high-frequency writes from large device fleets
- Energy systems: smart meters, battery storage telemetry, renewable asset monitoring
- Network telemetry: gNMI streaming, SNMP at scale, NetFlow records
- Satellite and aerospace: High-frequency telemetry from satellites, launch vehicles, and ground systems where data volume is extreme and decisions are time-sensitive
- Financial time series: tick data, price feeds, OHLCV aggregations
At high data volumes, InfluxDB’s columnar storage and object storage backend compress time series data aggressively and store it at a fraction of the cost of in-memory or block storage.
Elasticsearch for Time Series Data
Elasticsearch can be used for time series data storage and analysis, thanks to its distributed architecture, near real-time search capabilities, and support for aggregations. However, it might not be as optimized for time series data as dedicated time series databases. Despite this, Elasticsearch is widely used for log and event data storage and analysis which can be considered time series data.
InfluxDB Key Concepts
Columnar storage: InfluxDB stores data in a column-oriented format using both open source and proprietary standards for persistent storage and Apache Arrow as the in-memory representation. Columnar storage produces strong compression ratios and fast time-range reads.
Data model: InfluxDB organizes data into databases, measurements (equivalent to tables), tags (indexed identifiers used for filtering), and fields (the measured values). InfluxDB 3 supports unlimited tables and columns. Data models evolve without schema migrations or predefined column limits.
Query languages: InfluxDB supports standard SQL and InfluxQL. InfluxQL includes built-in time-series functions: gap filling, window aggregations, downsampling, and rate calculations from counter data.
Decoupled architecture: InfluxDB 3 separates ingestion, query compute, and storage into independently scalable components. Teams tune each layer to workload requirements rather than provisioning for peak across all three simultaneously.
Retention policies: Users configure retention policies that automatically expire data after a defined duration. No manual partition drops, retention scripts, or index rebuilds required.
Telegraf integration: Telegraf, InfluxData’s open-source data collection agent, connects to 400+ data sources out of the box and writes directly to InfluxDB. It is part of the standard telemetry collection stack for tens of thousands of teams worldwide.
Unlimited Cardinality: The InfluxDB 3 storage engine enables high-performance queries across tables with millions of columns without impacting query performance.
Elasticsearch Key Concepts
- Inverted Index: A data structure used by Elasticsearch to enable fast and efficient full-text searches.
- Cluster: A group of Elasticsearch nodes that work together to distribute data and processing tasks.
- Shard: A partition of an Elasticsearch index that allows data to be distributed across multiple nodes for improved performance and fault tolerance.
InfluxDB Architecture
InfluxDB 3 separates data ingestion, querying, compaction, and garbage collection into components that operate independently. This separation allows compute and storage to scale in different directions based on actual workload requirements.
Data written to InfluxDB flows through ingesters with millisecond-level latency and is immediately queryable. A background compactor consolidates new files and moves them to object storage. The query layer pulls seamlessly from both in-flight ingester data and object storage, so there is no gap between data arrival and query availability.
Object storage handles long-term persistence at low cost. Teams retain data at higher frequencies and for longer periods without driving up infrastructure costs on expensive storage tiers.
Elasticsearch Architecture
Elasticsearch is a distributed, RESTful search and analytics engine that uses a schema-free JSON document data model. It is built on top of Apache Lucene and provides a high-level API for indexing, searching, and analyzing data. Elasticsearch’s architecture is designed to be horizontally scalable, with data distributed across multiple nodes in a cluster. Data is indexed using inverted indices, which enable fast and efficient full-text searches.
Free Time-Series Database Guide
Get a comprehensive review of alternatives and critical requirements for selecting yours.
InfluxDB Features
High-performance storage and querying
InfluxDB 3 is optimized for time series at every layer: ingestion, storage, and query execution. InfluxDB 3.10 delivers significantly faster query performance compared to prior InfluxDB 3 releases, with the most pronounced gains on single-series lookups, real-time telemetry queries, and metadata operations. Performance varies by workload.
Retention policies
InfluxDB automatically expires data after a configured duration. No external orchestration required.
Data compression
InfluxDB 3’s storage engine delivers strong compression ratios on time series data. Background compaction continuously consolidates smaller files into larger ones that are cheaper to store and faster to query.
Horizontal scaling and clustering
InfluxDB 3 Enterprise supports horizontal scaling and clustering, distributing data and query load across nodes for performance and fault tolerance.
Data tiering
InfluxDB 3 automatically moves data between hot and cold storage tiers. Recent data stays accessible for low-latency queries. Older data moves to object storage, where it remains queryable at lower cost without manual lifecycle management.
Row-level deletions
Users delete individual data points or subsets within a table without dropping entire tables or databases.
Auto-Distinct Value Caching
InfluxDB 3.10 automatically creates caches for metadata queries, making operations like SHOW TAG VALUES significantly faster without manual cache configuration.
Processing Engine
InfluxDB 3 runs Python code directly inside the database for real-time transformations, anomaly detection, and forecasting. Plugins trigger on a schedule, via HTTP requests, or on data write with no external processing layer required.
Elasticsearch Features
Full-Text Search
Elasticsearch provides powerful full-text search capabilities with support for complex queries, scoring, and relevance ranking.
Scalability
Elasticsearch’s distributed architecture enables horizontal scalability, allowing it to handle large volumes of data and high query loads.
Aggregations
Elasticsearch supports various aggregation operations, such as sum, average, and percentiles, which are useful for analyzing and summarizing data.
InfluxDB Use Cases
Monitoring and alerting
InfluxDB stores and processes time series data from infrastructure, applications, and devices at scale. Combined with visualization tools like Grafana, teams build real-time dashboards and threshold-based alerting without query latency degrading as data accumulates.
InfluxDB stores the high-frequency feature data, model performance metrics, and inference telemetry that ML pipelines depend on. The built-in Processing Engine runs anomaly detection and forecasting models directly against live data without a separate compute layer.
IoT data storage and analysis
High write throughput and configurable retention policies make InfluxDB a fit for IoT deployments where sensors generate continuous data streams. Teams ingest at high frequency, retain what matters, and query across the full dataset with consistent performance.
Energy systems
InfluxDB manages telemetry from smart meters, grid infrastructure, battery storage systems, and renewable assets at the write rates and retention windows energy operators require. Cell-level monitoring, cross-site portfolio analytics, and long-horizon capacity planning all run on the same platform without architectural workarounds.
Real-time analytics
InfluxDB handles application performance monitoring, user behavior tracking, and financial data analysis in real time. SQL and InfluxQL support lets teams run complex aggregations and time-windowed queries without a dedicated analytics layer.
InfluxDB handles the cardinality and write throughput that infrastructure monitoring generates at scale: millions of unique tag combinations across hosts, services, containers, and endpoints. Teams query recent and historical data spanning months or years without separate storage tiers or query engines.
Satellite & Aerospace
InfluxDB stores and analyzes high-frequency telemetry from satellites, launch vehicles, and ground systems where data volume is extreme and query latency affects operational decisions. Object storage tiering keeps years of mission data accessible without runaway infrastructure costs.
Industrial AI
InfluxDB ingests continuous signals from PLCs, SCADA systems, and industrial sensors at the frequencies predictive maintenance and process optimization models require. The Processing Engine runs detection and forecasting plugins in-database, reducing latency between sensor data and actionable output.
Data historian augmentation
InfluxDB extends legacy data historians by capturing the high-resolution, high-frequency process data that traditional historians compress, downsample, or age out. Open SQL and InfluxQL access frees that data from closed historian interfaces, while object storage tiering retains full-fidelity history at a fraction of the cost of expanding the existing system. Teams bridge plant-floor signals into modern analytics or ML pipelines and run Processing Engine plugins against live and archived data, modernizing without ripping out the historian they already depend on.
Elasticsearch Use Cases
Log and Event Data Analysis
Elasticsearch is widely used for storing and analyzing log and event data, such as web server logs, application logs, and network events, to help identify patterns, troubleshoot issues, and monitor system performance.
Full-Text Search
Elasticsearch is a popular choice for implementing full-text search functionality in applications, websites, and content management systems due to its powerful search capabilities and flexible data model.
Security Analytics
Elasticsearch, in combination with other Elastic Stack components, can be used for security analytics, such as monitoring network traffic, detecting anomalies, and identifying potential threats.
InfluxDB Pricing Model
InfluxDB offers several pricing options, including a free open source version, a cloud-based offering, and an enterprise edition for on-premises deployment:
- InfluxDB 3 Core: Free, open source, self-managed. Provides core time series database functionality on the InfluxDB 3 architecture.
- InfluxDB Cloud Serverless: Fully managed, multi-tenant cloud., pay-as-you-go. No infrastructure to manage. Available across major cloud providers.
- InfluxDB Cloud Dedicated: Managed deployment on dedicated infrastructure for workloads requiring isolation or hardware-level configuration control.
- InfluxDB 3 Enterprise: Self-managed enterprise deployment with clustering, role-based access control, automated backup and restore, and production support.
Elasticsearch Pricing Model
Elasticsearch is open-source software and can be self-hosted without any licensing fees. However, operational costs, such as hardware, hosting, and maintenance, should be considered. Elasticsearch also offers a managed cloud service called Elastic Cloud, which provides various pricing tiers based on factors like storage, computing resources, and support. Elastic Cloud includes additional features and tools, such as Kibana, machine learning, and security features.
Get started with InfluxDB for free
InfluxDB Cloud is the fastest way to start storing and analyzing your time series data.
