WARNING: For the most current instructions and downloads please visit the official documentation here.
Today we are officially announcing the InfluxData package repository. This package repository can be used with Ubuntu, Debian, RedHat, and CentOS Linux package management systems, with more distributions and operating systems coming soon. You will now be able to automatically download and install the latest InfluxData releases as they become available. In addition, all releases are GPG-signed, ensuring that all packages are verified and secure before installation.
Configuring
To get started, follow the instructions below for your Linux distribution of choice:
CentOS Users
Currently CentOS 6 and 7 are the only supported versions. To add the InfluxData repository, copy and paste the following into a terminal as an administrator/root user:
cat <<EOF | tee /etc/yum.repos.d/influxdb.repo
[influxdb]
name = InfluxDB Repository - RHEL \$releasever
baseurl = https://repos.influxdata.com/centos/\$releasever/\$basearch/stable
enabled = 1
gpgcheck = 1
gpgkey = https://repos.influxdata.com/influxdb.key
EOF
Once the InfluxData repository has been added, you can install the latest stable release of InfluxDB using the following commands:
yum install influxdb
And to remove InfluxDB:
yum remove influxdb
RedHat Enterprise Linux Users
As with CentOS, only RHEL 6 and 7 are currently supported. To add the InfluxData repository, copy and paste the following into a terminal as an administrator/root user:
[influxdb]
baseurl = https://repos.influxdata.com/rhel/\$releasever/\$basearch/stable
enabled = 1
gpgcheck = 1
EOF
yum remove influxdb
Ubuntu Users
For Ubuntu, versions 12.04 (Precise), 14.04 (Trusty), 14.10 (Utopic), and 15.04 (Vivid) are currently supported. To add the InfluxData repository, copy and paste the following into a terminal as an administrator/root user:
curl -sL https://repos.influxdata.com/influxdb.key | apt-key add -
source /etc/lsb-release
echo "deb https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | tee -a /etc/apt/sources.list
apt-get update
apt-get install influxdb
apt-get remove influxdb
Debian Users
For Debian, Jessie and Wheezy are the currently supported releases. To add the InfluxData repository, copy and paste the following into a terminal as an administrator/root user:
source /etc/os-release
test $VERSION_ID = "7" && echo "deb https://repos.influxdata.com/debian wheezy stable" | tee -a /etc/apt/sources.list
test $VERSION_ID = "8" && echo "deb https://repos.influxdata.com/debian jessie stable" | tee -a /etc/apt/sources.list
apt-get update
What’s Next
And that’s it! Once the configuration above is applied, your system will automatically be able to install and upgrade to current and future stable versions of InfluxDB (and other InfluxData applications) as they are released. Of course if you run into any issues at all, please don’t hesitate to contact us at contact@influxdb.com.
Don’t see your distribution listed here? Create an issue on Github, and we’ll try our best to get it added the repository.
Pin It on Pinterest
Share This
Contact Sales
